Resurfacing Wet clutch discs
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Topic: Resurfacing Wet clutch discs
    Posted: 17 Jul 2011 at 3:24pm
Just wondering, is there a way to renew the friction surface on wet clutch discs?  It seems like you should be able to find someone who would take your worn out disc, clean it down to bare steel, and put on a new friction surface.
Hurst
1979 Allis Chalmers 7000
5800 Hours
Kcgrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2011 at 4:10pm
There is a place in Ft Wayne IN that may be able to help you 260-426-3331 Thats what they do I am told
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2011 at 4:24pm
Thanks for the info!  I still need to get a machinist's straight edge to check for warpage, as only the outer surface of the disc really wore, making me think it kind of beveled, but if it's straight, I'll definitely consider resurfacing if it's not cost prohibitive
Hurst
Edited by Hurst - 17 Jul 2011 at 4:25pm
5800 Hours
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2011 at 5:01pm
Hurst, Mutual Wheel has done brakes and clutches for us when I was rebuilding presses and other machine tools. Look around on their website, they probably would do it for you. http://www.mutualwheel.com/
HARVESTMOONPULLER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HARVESTMOONPULLER Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2011 at 11:32pm
http://fortwayneclutch.com/
They do our clutches and the even do tractor brakes. If you got a clutch or brake that needs new frictions they can do it. Wouldnt go anywhere else. Especially since their only an hour away lol
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2011 at 12:50am
how hard is it, or is there anyplace to get the pieces and re-do the things yourself?
Post Options Post Options   Thanks (0) Thanks(0)   Quote HARVESTMOONPULLER Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2011 at 2:31am
Ive never done a clutch myself but i watched fort wayne clutch do mine and they made it look easy. Ive bought brake pads for my 19 and 17 and did those myself. That was fairly easy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2011 at 5:21pm
If we're talking about clutch discs from clutch packs in the trans, I would think it would be easier to replace them than to reline. If it's like an auto trans, when the discs start slipping, they tear up the steel separators. If it's not much work to get at them, I can see trying, but if it's major tear down, I wouldn't take the chance. Just my $02 worth...
Post Options Post Options   Thanks (0) Thanks(0)   Quote HARVESTMOONPULLER Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2011 at 9:29pm
I just split my 200 apart this afterrnoon. Power director quit shifting into high the clutch pack was completly destroyed. Ill be goin to fort wayne clutch in the morning ill find out what theyll do with it and let you know if they resurface the frictions or if they just replace them. Also if yours wore at a bevel check you steel seperators mine are warped. Guess power directors dont like fast hard pulls as much as i do.
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2011 at 11:19pm
Check your pistons for "flat" too. We're talking two different things here but the aluminun piston in the high side PD clutch on my 8070 was concave a little.
