HELP 7010 powershift Dr Allis Mack |
Clay Bragg
Bronze Level Joined: 15 Sep 2009 Points: 16 |
Posted: 28 Jun 2011 at 9:13pm |
I was mowing hay with my 7010 powershift today,(disked 200 acres with 20ft 480 international disk last month with no trouble)ground speed started slowing down.looks like hyd oil coming from behind the flywheel.can something screw up to cause excessive trans preasure?1800 rpm light has always worked properly and is not on abnormally.Anything to check before I split it?anything else to service inside while its down. thanks Clay
MACK
If it is hyd. oil, the nut on ftont of PS may have come off. If the nut came loose it is a complete rebuild.
If you are lucky it is engine oil from rear main seal. MACK
Clay Bragg
definatley hy tran wher can i purchase some good splitting stands? |
bill2260
Silver Level Joined: 30 Mar 2010 Points: 215 |
What causes the nut to come off power shift? Have seen post on this before. Thanks, Bill
Orange Level Access Joined: 12 Sep 2009 Points: 19628 |
The locking tab ring allows the nut to start to work loose and then eventually shears off the tab and then bad things happen. It is not terribly common but, as these tractors get older we may see more. Whenever I have a PowerShift tractor split for any reason, I put a stake/center punch mark on the inside diameter of the nut, inline with a keyway on the clutch housing nose so the nut can't ever back off. If I ever need to remove the nut for trans repairs years down the road, I use a sharp chisel and split the nut at the center punch mark.
MACK
I have seen the housing break off behind the nut, have saw the threads stripped with the lock still in tack. No good reason, but it happens from time to time.
As far as splitting stands, a set to support the motor is all you need. Remove the PS with the motor then remove PS from motor. MACK
Clay Bragg
can you check clutch packs for wear or would you just replace them all?torque limiter?Bearings?thanks |
Carl(NWWI)
Orange Level Joined: 13 Sep 2009 Location: NW WI Points: 948 |
here's a good place for stands, spendy, but safe..
MACK
I would replace clutch plates in C1 and A2. Any others thar are warped or has foreign materal through them. As far as wear, check the splines on plates for wear. The plates very seldem wear unless they are warped. MACK
