Help with a D-21 |
Wendell,W.N.H.
Joined: 28 Jul 2012 Location: Langdon,N.H. Points: 28 |
Topic: Help with a D-21Posted: 24 Jul 2023 at 9:06am |
I have a 1966 D-21 with a non- turbo engine. Has been running fine, but now will run for a few seconds then quit. I replaced the inline filter under tank (twice) and spin on is new. I pulled off the spin imediately after it quit one time and it was full of fuel. I checked power to the shut off on pump and it is getting power while key is on. Air filter is new. It will start right back up after it quits. Does this mean my problem is with the injection pump? The pump is a Stanadyne, DCGFC629-2AG. Thanks for any help
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5208 |
Posted: 24 Jul 2023 at 11:24am |
flex ring inside pump is breaking down and the pieces are plugging the return fitting in top cover of inj pump. You can take the fitting out, remove the ball and it should run, this is a temporary bandaid. It will need serviced soon. You can verify this by loosening the bolt on side of pump with 1/2" wrench, and let the fuel leak out the side. It stays running it confirms the return is plugged making it lose power and dying.
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 9004 |
Posted: 24 Jul 2023 at 11:38am |
...it will not get better,only worse. Time to start getting educated on steps for pump removal/installation. The rebuild should last longer than you.
den/southern illinoi
Joined: 11 Sep 2009 Location: Sparta, Illinoi Points: 2092 |
Posted: 24 Jul 2023 at 4:11pm |
And one of those that answered your question (injpumpEd) is who can rebuild it for you Den
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor. |
Tim NH
Joined: 16 Oct 2012 Location: Lancaster NH Points: 1156 |
Posted: 24 Jul 2023 at 5:57pm |
Hi Wendell, Den is right you want Ed to do it. He's done two of my tractors, and injectors. He will talk you thru removal. and installation. Tim
sparky
Joined: 13 May 2011 Location: So. Indiana Points: 1838 |
Posted: 24 Jul 2023 at 6:00pm |
Yep,Ed gets my vote also.
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5489 |
Posted: 24 Jul 2023 at 9:48pm |
I have nothing but good things to say about Ed’s work. Right man for the rebuild for sure.
