7000 Special
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Topic: 7000 Special
    Posted: 04 Oct 2022 at 5:05pm
I see there is a rare 7000 Special on Auction Time this week. What exactly was so unique about this model? I don't have Norms Bible here at the house. Thanks, Ryan
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2022 at 5:14pm
Not really rare, just has the heavy duty front axle like a 7020 and 8 lug wheels. All the specials I've seen labeled as such have been black chassis tractors though. Never seen a maroon that said special on it. But I have heard they put the hd axle on some maroons.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2022 at 6:32pm
So that was the only difference just the bigger front axel?
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2022 at 9:49am
Ryan. I look at it this way. the maroon belly 7000 was a 200 with new sheet metal. The black belly was more of 7010/7020 version.. and yes, the heavier front end was part of that. Dale
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2022 at 12:16pm
Other than the appearance and the heavy front axle, and being AC, a 7000 no matter the series is a class all by itself. The black chassis just is a little different in that it uses the low side power director clutch to stop and start movement. Still uses same principal power director as before, Under, direct, (like 190/200) and over drive(what made a 7000 better)
cowkicker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowkicker Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2022 at 3:42pm
My maroon, open station has the heavy axle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2022 at 5:07pm
Does it have the "special" decal anywhere? I've never seen a maroon labeled as such, but know they are out there.
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2022 at 9:07pm
My black belly 7000 has the heavy axle and does not have the special decal...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2022 at 11:38pm
Can you post a picture of decal
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2022 at 9:30pm
If I am not mistaken the Special decal was a local promotion from an AC area branch.
Also the gears in the 7000 addressed the gear jumping issue of the 180/190/200  versions.   The shift lugs had a small degree of 'hold in ' angle... some to aggressive but it fixed the issue.
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2022 at 8:03pm
Wasn't the hydraulic pump moved on the Black 7000? I had a red 7000 and it was special to me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2022 at 6:02am
No.
