7000 Special |
| Author | ||
Ryan Renko
Joined: 12 Sep 2009 Location: Edwardsville, I Points: 2350 |
Topic: 7000 SpecialPosted: 04 Oct 2022 at 5:05pm |
I see there is a rare 7000 Special on Auction Time this week. What exactly was so unique about this model? I don't have Norms Bible here at the house. Thanks, Ryan
| Sponsored Links | ||
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5208 |
Posted: 04 Oct 2022 at 5:14pm |
Not really rare, just has the heavy duty front axle like a 7020 and 8 lug wheels. All the specials I've seen labeled as such have been black chassis tractors though. Never seen a maroon that said special on it. But I have heard they put the hd axle on some maroons.
Ryan Renko
Posted: 04 Oct 2022 at 6:32pm |
So that was the only difference just the bigger front axel?
orangereborn
Posted: 05 Oct 2022 at 9:49am |
Ryan. I look at it this way. the maroon belly 7000 was a 200 with new sheet metal. The black belly was more of 7010/7020 version.. and yes, the heavier front end was part of that. Dale
injpumpEd
Posted: 05 Oct 2022 at 12:16pm |
Other than the appearance and the heavy front axle, and being AC, a 7000 no matter the series is a class all by itself. The black chassis just is a little different in that it uses the low side power director clutch to stop and start movement. Still uses same principal power director as before, Under, direct, (like 190/200) and over drive(what made a 7000 better)
cowkicker
Posted: 05 Oct 2022 at 3:42pm |
injpumpEd
Posted: 05 Oct 2022 at 5:07pm |
Does it have the "special" decal anywhere? I've never seen a maroon labeled as such, but know they are out there.
Adam Stratton
Posted: 05 Oct 2022 at 9:07pm |
My black belly 7000 has the heavy axle and does not have the special decal...
Mikez
Posted: 05 Oct 2022 at 11:38pm |
Can you post a picture of decal
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3666 |
Posted: 06 Oct 2022 at 9:30pm |
If I am not mistaken the Special decal was a local promotion from an AC area branch.
Also the gears in the 7000 addressed the gear jumping issue of the 180/190/200 versions. The shift lugs had a small degree of 'hold in ' angle... some to aggressive but it fixed the issue.
allisrutledge
Joined: 30 Mar 2010 Location: SurgoinsvilleTN Points: 1361 |
Posted: 09 Oct 2022 at 8:03pm |
Wasn't the hydraulic pump moved on the Black 7000? I had a red 7000 and it was special to me.
Posted: 10 Oct 2022 at 6:02am |
No.
