What machines had the 301/2900?
4oranges View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 4oranges Quote  Post ReplyReply Direct Link To This Post Topic: What machines had the 301/2900?
    Posted: 01 Oct 2022 at 4:23pm
Well my 7020 send a rod through the block yesterday. Wondering what other machines out there have the same turbo 301 in it. I'd like to find a running engine (swap parts of from a combine) and drop it in.
Had considered putting a 426 in there and making it a 7045 but don't want to mess with the radiator since the new on is only a year old.
Any ideas or thoughts are always welcome, heck I'd consider putting a 5.9 Cummins in it if I could do it for the right price. 😁
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2022 at 4:39pm
Technically, your 649-TI engine configuration (turbocharged/inter-cooled/piston cooled/ 145 rated flywheel HP) was only used in the 7020 tractor and SOME M-3/L-3 Gleaner combines. How many hrs were on your failed engine ?? What failed?? piston pin bushing or connecting rod bearing ??
Edited by DrAllis - 01 Oct 2022 at 4:43pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 4oranges Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2022 at 8:08pm
Had around 12,000 hours (5500 on a inframe kit years ago) still chopping silage up here so haven't opened it up but by the looks of the holes in the block I think connecting rod bearing failure.
I figured there was something special about the engine, had to put a new head on it a couple years ago and it was a pain to find one. Maybe I'm better off finding a 426...
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2022 at 8:50pm
Replace lower end bearings ever 5000 hrs. That 5.9 is a good setup. Planetary are a little light for a 426.                        MACK
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2022 at 10:11am
My opinion, and only my opinion (because you know what they say about opinions!) is to do it back up original, and cut no corners
Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2022 at 1:06pm
Hard to beat a 301 but the 5.9 would be appealing to me if I had issues finding a good 301. Plenty of 301’s built so finding one shouldn’t be an issue even if you need to rebuild one.
ajl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ajl Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2022 at 11:32pm
I think the finding a 426 and making it a 7045 is a good plan if you can't find a 301 TI.  It should bolt right up to the transmission without much mods and the fact that your rad is new should keep it cool.    A 5.9 Cummins would likely also have the same amount of hp but would need more modification.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2022 at 7:18am
technically making it like a 7030/7040 since it would have 2 pinion differential still, so keep that in mind if you wanted to work it harder than originally designed for. I put my 7040 to the test 300' at a time, with over 300hp lol! Constant field use at high hp stresses things way more though.
