D10 control valve
Ranse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Topic: D10 control valve
    Posted: 02 Aug 2018 at 8:48pm
I've been trying to fix these valves for years. The leaks have been a big problem. Now it's bypassing so bad it makes the 3pt hitch impractical to use. It won't hold anything up over a minute or two. I've been told by a couple of hydraulic shops, this is something you can't fix. Once the housing is worn, that's it. I'm not sure if that's true or not, but I don't know what to do for it. There isn't any seals inside. I'm thinking about putting an aftermarket valve on it. I hate to, because I will have to sacrifice the traction booster. I'd like to find one about the same size and appearance so I can try to make it look as authentic as possible.
This is the original valve and traction booster valve. I have a second on the tractor that is not much better.
This is the only diagram of this valve that I know of. I've seen it in several books and on line. Most of the parts are NLA. I had new end caps made because that was were my leaking problem was. Of course, that won't stop it from bypassing fluid back into the transmission. If there is anything you can do to slow it down I could probably live with it. Every tractor I have, the lift leaks down over some time, but not like this one. Thanks.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2018 at 5:51am
Yes they are a pain and like you, no other parts/controls are like them that I have found.
Do you really need TB? If not then a replacement unit should be easy enough to do.
Charlie
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2018 at 6:51am
I've been thru the same thing exactly on my D10 . It is due an overhaul this winter and I have a 2 spool open center valve I plan on putting on it. I ordered it from surplus center.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2018 at 8:50am
You could machine the valve body to a slightly larger diameter holes. Then make a new plunger to fit. Not cheap, but would cure the problem. HTH Tracy
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2018 at 1:04pm
Sugestion.Mike area for o rings real good  and compare size with S A E and metric.Metric might work better.Had air compressor at work and pop off valve leaked miked and change to metric and fixed. On relief valve reseat.Took ten thousands off my B and it holds good now.
Bobby G. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bobby G. Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2022 at 6:56pm
Can you ream the bore on those?
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2022 at 7:52pm
Can anyone suggest a repair shop, who is the best?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2022 at 8:14pm
I think I have one of those valves here removed from a parted out tractor. Although it was awhile ago and I could not vouch for the condition of the valve.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2022 at 8:18pm
the POST is 4 years old....
