Lift Arm Latches
ddlong View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddlong Quote  Post ReplyReply Direct Link To This Post Topic: Lift Arm Latches
    Posted: 31 Oct 2017 at 6:09am
https://images.craigslist.org/00V0V_hj4X5eJVIG4_600x450.jpg
Are there different size latches for the lift arms for the Snap Coupler system? Will WD/WD45 fit D14/15/17/19? It looks like the CA/B arms are a different size?
Going to need a set for a WD45.
Don in Hawkeye MO
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2017 at 6:11am
Pretty sure they all fit, evrything.
Those are the newer, heavy duty ones....
.. the hole allows a 1.25" bar to be installed to keep things from breaking I think.
wait 5 minutes and 4 guys will have 3 imore replies !!
Jay
Larry in NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in NC Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2017 at 7:10am
B, CA, D10 and D12 are the same and are different from WD WD45 and the other D series tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddlong Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2017 at 7:32am
That’s what I thought. The latch itself is the same as all the Snap Coupler emplements use the same size bar to go into the latches.
Don
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2017 at 7:48am
I have two or three sets for the WD45 tractors.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2017 at 9:26am
I did a little research on this issue a few years ago.
This is what I found out.....I think I got it right!
As stated, the CA, D-10, etc use a different style coupler.
The 3 photos show what I think are the latest and heaviest latches;
probably for the 175 and up tractors altho they should fit the WD-WD-45s as well.
The last photo shows a comparison and the extra "meat" in the casting of the HD unit.
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2017 at 9:30am
I've got a few sets left also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2021 at 10:04am
The D17 would probably have used the #4 lighter couplers with the spreader bar.  I would imagine the #5 came out about 61 with the D19, a heavier tractor, and was carried through to the snap coupler versions of the 190.  JMO.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2021 at 10:16am
Dad's 1967 series 4 had the later/thicker latches, same as D-19 and 190.
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2021 at 12:17pm
My Series 1 D 15 has lift latches similar to the picture . What goes in the round hole ? A spreader bar ? What purpose would that be ? THANKS !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2021 at 12:26pm
I think it just stabilized things more. Dad bought a SC plow for WD in mid 60s. Put SC hitch on and bought new arm latches. They are the heaviest latest version. I'm sure they superceded everything before.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2021 at 1:24pm
Thanks Steve , maybe other tractors are different but on my D 15 I don't see how anything could move unless something broke ? Maybe the lift latch could slip off the end of the lift arm ? THANKS again !
Robert Musgrave View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robert Musgrave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2021 at 5:31pm
Those heavy-duty lift latches showed up when the "big disc" (13.5') snap-coupler with a chain attached to lift arms and the pulley was on the snap-coupler tongue to activate the Traction Booster.  The WD-45 had a D-17 upgrade and duals--it was all it could handle. One of the neighbor BTO's of that era had a 190 that I believed only pulled an 11-foot disc.  At least that was the way it was on our farm.  If you were used to your foot being on the rear platform; you had to be careful you didn't snag your work shoe when lifting or lowering an implement!   R. Musgrave
This page was generated in 0.250 seconds.
