D-17 allis chalmers not running smooth and going d
CE Mississippi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CE Mississippi Quote  Post ReplyReply Direct Link To This Post Topic: D-17 allis chalmers not running smooth and going d
    Posted: 28 Nov 2021 at 8:28am
I rebuilt the engine put electronic ignition new plugs and wires. Rebuilt carburetor. Put old manifold on with new gaskets with the round metal plates on them . Tractor cranks but runs rough and at times backfires and air comes out of carburetor. Any ideas.??
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2021 at 9:08am
Firing order is 1-2-4-3. Clockwise rotation of distributer looking down to top.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CE Mississippi Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2021 at 2:00pm
Checked that . The wiring is correct thanks.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2021 at 3:39pm
Has the timing been checked?
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2021 at 3:53pm
First would be timing and firing order. Next would be carb adjustment
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2021 at 8:06pm
Pull one plug wire off. Do it on every cylinder. If you pull one off and no change then you know something is wrong with that one. Just because they are new don't make them good.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2021 at 8:15pm
I'm sure if you put new electronic ING. on, it needs timing checked and adjusted.            MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2021 at 9:08pm
Check it again...sounds like wires crossed
Post Options Post Options   Thanks (0) Thanks(0)   Quote CE Mississippi Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2021 at 10:41am
Double checked wires . All good . Timing ok . Now checking valve adjustment. A little confused. On page 18 of shop manual it shows what to adjust valve tapper gap to with number 1 cylinder at TDC . And also what to adjust remaining valves to with number 4 cylinder at TDC. On the D-17 number 1 and 4 are TDC at same time??
Post Options Post Options   Thanks (0) Thanks(0)   Quote CE Mississippi Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2021 at 2:54pm
Got valves adjusted. Runs like a top thanks fellas. Now I have to work on clutch. When you push in clutch it doesn’t stop the tractor. I put a new plate in . You think it’s the pressure plate ??
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2021 at 2:58pm
Also do a compression test and report on the readings.
If there are wacky readings, it could be valve lash.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2021 at 3:25pm
I would still do a compression test.
For our knowledge, how out of adjustment were the
valves, would you say some were not even closing?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CE Mississippi Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2021 at 6:05pm
They were all tight . Had to loosen all up and set to the right spacing. Not sure how to do the clutch pressure test .
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2021 at 7:30pm
Glad you got it fixed, running with exhaust valve not seated can (will) lead to damage, especially under working loads.
As for the clutch I don't know. Ordinary dry disk single clutches they always tell you to adjust the clutch pedal free play per the manual. Too much free play may mean you effectively cannot push in the pedal far enough to disengage the clutch, could give a dragging effect. Could you have put the disc in backwards? Why did you change it, did the old one have the same issue?
Wait for the guys who know to give clutch advice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CE Mississippi Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2021 at 7:39pm
I had to put a rear seal in the engine and the plate had never been changed so I replaced it while I had it apart. I don’t see any way to adjust it . Thinking I should’ve put a new pressure plate in as well. Live and learn.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2021 at 8:08pm
Clutch free play is adjusted at the clutch pedal. The clutch pedal should have a set amount of distance while the pedal is back until it is pushed forward as it touches the throw out bearing. That distance is in your owners manual. I do not have a D17 manual so I would have to look it up to be sure. That adjustment if it is like our D15 is adjusted by detaching the clutch rod from the clutch pedal and turning it in or out depending which direction you need to adjust the free play.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CE Mississippi Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2021 at 6:19am
Ok thanks I will check that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2021 at 9:10am
[QUOTE=CE Mississippi] Double checked wires . All good . Timing ok . Now checking valve adjustment. A little confused. On page 18 of shop manual it shows what to adjust valve tapper gap to with number 1 cylinder at TDC . And also what to adjust remaining valves to with number 4 cylinder at TDC. On the D-17 number 1 and 4 are TDC at same ]
They are both up on TOP center but not TDC and the camshaft turns half speed of crank so the valve lash is adjustable on different valves in different positions. Not confusing when you understand how it works.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CE Mississippi Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2021 at 9:21am
Got it thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2021 at 4:37pm
First check clutch adjustment. Depending on how hard it slid back together you could've bent the disk. Or put the disk in backwards.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CE Mississippi Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2021 at 5:23pm
The d-17 has no adjustment other than the pedal and that’s just for leg length. Gotta split it to be sure all is correct. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2021 at 6:46pm
The D-17 has adjustment on each pressure plate finger !!  All the clutch pedal rod does is position the pedal either farther back or forward when released.  I have tools made to be able to adjust finger height when the tractor is assembled. Assuming there's nothing mechanically wrong with your clutch repair, I'll bet the fingers are too far away from the throwout bearing. So they need to be moved closer. You still want as much freeplay as possible, but the clutch should release when the pedal is pushed clear down.  Always test your clutch adjustment as soon as the engine is rolled up tight and two bolts installed. Place the PTO lever in gear. Clamp a 10 inch Vise-Grips on the PTO shaft at the rear of the tractor. Transmission in neutral. Hand clutch in neutral. Someone in the seat holding the clutch pedal 100% fully DOWN. You should be able to turn the PTO shaft with little effort.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CE Mississippi Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2021 at 11:42am
Will try that thanks.
Also I am changing the oil in the transmission. The manual calls for 6 gallons of 80w oil. Is there a substitute or should I find 80w. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote CE Mississippi Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2021 at 11:54am
Looks like the fingers are about an inch from the throw out bearing .
Post Options Post Options   Thanks (0) Thanks(0)   Quote CE Mississippi Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2021 at 12:06pm
That’s with no pressure on clutch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CE Mississippi Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2021 at 3:42pm
That’s what it was DR got it going . Thanks now to the shuttle clutch. It creeps when it’s in the neutral position. But it will work in the high and low positions.
eryanh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eryanh Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2021 at 3:26pm
Use 80-90. If you ever find straight 80 then consider yourself lucky.
Edited by eryanh - 03 Dec 2021 at 3:29pm
1958 AC D17 Series 1 NF
1949 Farmall M NF
1938 AC B
Post Options Post Options   Thanks (0) Thanks(0)   Quote eryanh Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2021 at 3:29pm
Not sure if you mean the power director or if its an actual shuttle but if its PD then when the oil is cold, it will creep. Once warmed up it shouldn't do it at all. That is if the transmission is in gear.
1949 Farmall M NF
1938 AC B
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2021 at 6:56pm
Don't use 80/90 in the Power Director clutch. Use Universal hydraulic/transmission oil and even at that, until the oil temp is up to 150 degrees or more there will be some creeping in neutral. It will creep the most in LOW gear. It will creep the least in 4th gear. This is normal for an oil bathed clutch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CE Mississippi Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2021 at 4:58am
Will do thanks DR
