Gleaner Combine Cab ??
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner Combine Cab ??
    Posted: 30 Aug 2021 at 6:59pm
My first memory of a our Gleaner collection was an "A" machine with a "MEADE" (I believe) aftermarket cab with a little heater to the right of the seat on the floor Smile. What series of machines did ALLIS/Gleaner produce their own cabs ??
Edited by FREEDGUY - 30 Aug 2021 at 6:59pm
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2021 at 7:55pm
L and M
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2021 at 8:04pm
Late 60's with K and F for sure because they had the massive piano type hinge at the front so you could fold the cab forward to lower hauling height, by using the throat to lower and raise back up the cab structure.
Post Options Post Options   Thanks (1) Thanks(1)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2021 at 8:07pm
WOW !! That I would have liked to see LOLLOL !! Ingenious !! Thanks for that info Clap
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2021 at 8:15pm
Maybe later C 2?  Not sure, I had one and don't remember, will see if I can find some old pictures.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2021 at 9:04pm
Later E A and C had a factory cab. Two piece windshield, came from factory with bottom half on combine, top half on truck. Bolted top half on at dealership.              MACK
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2021 at 9:23pm
A factory installed cab or an Allis built cab?
Wink
I am a Russian Bot
Bret (OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bret (OH) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2021 at 6:01am
Grandpa had an E, maybe 64 0r 65 model year with a cab.  Don't know if it was factory installed or installed by the dealer, but it had a unique though rather useless feature that allowed the roof to be raised by the use of a spring loaded handle mechanism on each side near the roof with the hinge at the back by the grain tank.  I don't remember him ever raising it, so I don't know how high it raised, and only assumed that it was so the operator could raise the roof to allow standing up during operation, or maybe it was for ventilation.
Doesn't answer the original question, but just came to mind when combine cabs were mentioned.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2021 at 6:11am
I believe the 1968 Gleaner F & G were among the 1st gleaner mfg cabs. They were all “Flat windshield” & offered with the tilt forward option -like DrAllis mentioned earlier.
Earlier aftermarket cabs included Stopler, Cozy Cab, Full vision, & others.
Edited by AC7060IL - 31 Aug 2021 at 6:41am
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2021 at 6:42am
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2021 at 6:55am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2021 at 7:01am
That be a model K-F-or G.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2021 at 7:11pm
That's an AWESOME pic 7060 ClapClap !! Thank you very much for it Big smile
This page was generated in 0.414 seconds.
