7040 pto seal leaking
nickia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Topic: 7040 pto seal leaking
    Posted: 11 Aug 2021 at 8:42pm
much of a job changing the pto seal on a 7040?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2021 at 9:13pm
Easy if you don't mind some oil in your face. Remove draw bar, drain oil , remove plate under PTO Housing, remove pin and nut from inner shaft then remove it, remove bolts behind outer shaft flange, and be ready to catch gears when outer shaft comes out.         MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2021 at 8:43am
thank you Mack
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2021 at 8:57am
If you search on the site there are some good pics and instructios posted. Cant remember the members name, did my 8050 last year. The pics really helped.
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2021 at 11:14am
I highly recommend draining the oil, and dropping the cover the night before and let it drip. Won't keep all the oil off of you, but will help to keep it to a minimum.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2021 at 6:04pm
Here’s a link to past posts about 7000 series pto seal repair.
https://www.allischalmers.com/forum/7040-pto-leak-repair-procedure_topic151418.html
This page was generated in 0.984 seconds.
