Shuttle Clutch ?
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: Shuttle Clutch ?
    Posted: 02 Feb 2021 at 6:06pm
Can someone explain what it is on a tractor ? Is it similar to a hydro tranny on a combine ? There is a post on AT about a 170 with it today and I've read about other tractors with this feature. Thanks
nickia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2021 at 8:17pm
my backhoe has a shuttle shift on it  you put it in a selected gear and then there is a big "stick" on the left had side  that you push forward for forward motion and pull back for reverse movement.  very handy for use on a loader tractor no clutching going from forward to reverse
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2021 at 8:31pm
Changes pto speed...850rpm if I remember correctly
Kenny L. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2021 at 11:37am
I've it on my D-15 that has a 415 allis loader on it and works like Nick said and my pto is 540 rpm.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2021 at 4:27pm
Not even remotely similar to a hydro. Instead of a two speed power director it has two same speeds one foward one reverse. When you push the lever foward would be low on a regular tractor it goes foward whatever gear the transmition determine your speed. Pull back to center on the stick tractor stops both power director clutches are disengaged. Pull back on the lever engages what would be high clutch but instead power flow is reversed so now your going backwards in whatever gear the transmition is in.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2021 at 4:34pm
Dave
What you describe is bassawkards for any D Series I have driven ( 14, 15, 17)
Power Director Forward for High Range, Backward for Low Range.
G
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2021 at 4:35pm
Thanks for the description of HOW it works and makes sense of the replies that Doc gave to the guy about PTO (dual) speeds .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2021 at 4:59pm
Gary I'm sure your correct Im sorry I haven't drove one since the 1970's.
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2021 at 8:19pm
I plan on installing a shuttle clutch torque tube out of a I60 into my D15 II and it would be awesome if the PTO still was normal 540. I read somewhere that the shuttle gears change the PTO speed.
www.awtractor.com
A&W TRACTOR 920-598-1287
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2021 at 8:23pm
how fast is the pto on a wd or a wd45?  im sure they are slightly faster than 540?  any one?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2021 at 8:33pm
Any A-C with a shuttle clutch has a faster than normal PTO. Memory tells me 800 to 850 RPM at full throttle. A WD45 or D-17 is normally 650 ish.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2021 at 9:55am
I have an I600 with a shuttle. The PTO has the 1000 rpm spline so it must be close. The DR. has it right. The PTO on my H3 crawler with a shuttle is 540 PTO. It has a rear gear box to correct the PTO to 540 unlike the tractors .
This page was generated in 0.150 seconds.
