char-lynn seal kit |
mhankins ![]() Silver Level ![]() Joined: 19 Feb 2019 Location: Arkansas Points: 134 |
![]() ![]() ![]() ![]() ![]() Posted: 07 Sep 2020 at 8:25am |
I am looking for a seal kit source for the torque multiplier on my wd45. So far all I have found are the seal kits for the pump,but mine is leaking out of the lower seal where the steering shaft connects.
Play Farmer ![]() Orange Level ![]() Joined: 13 Jan 2016 Location: NNY Points: 732 |
Measure the seal and you should be able to find one on line pretty easy.
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7455 |
A local hydraulic shop should have what you need.
Michael V (NM) ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: NM Points: 2454 |
Try this
Eaton power products No.21122 I ordered this from Force America several years ago, its a complete seal kit, with instructions on how to "time" the gears.. |
Thanks Michael. I couldn't find that part number listed,but I will contact the company. |
here ya go
Thank you!
Midwest steering has the seal kits if anyone else is looking.
HELP!! Ok,finally got around to taking the multiplier off and replaced the seals,butt... when I tighten everything down it will not turn. I timed it according to the pics above and tried the spacers in each position.The coupler shaft that goes between the rotor and the out put shaft at the lower part has different thickness splines on either end and I have tried those in each position. This is a series 101 which shows a little difference than the one pictured as to how many seals are used as mine doesn't have the larger orings sealing the case and spacers. Any Ideas?
Never mind,got it going
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8534 |
Want to fess up ?
Put it together from the bottom up instead of the top down. ??? worked
