gear reduction stater |
dakotawc ![]() Bronze Level ![]() Joined: 17 Feb 2013 Location: Clayton SoDak Points: 58 |
![]() ![]() ![]() ![]() ![]() Posted: 20 Oct 2020 at 1:01pm |
Should I repair or replace the starter on my 8070? Drive won't stay engaged now with the cold weather. Any comments on replacement gear reduction starters , good or bad? Where did you purchase yours? Thanks for your input. This site is the BEST!
Joe(TX) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
If the rest of the starter is good you can replace or clean the starter drive.
lowell66dart ![]() Orange Level ![]() Joined: 10 Jul 2013 Location: Paulina La. Points: 964 |
Do a search on Google for 7000 series gear reduction starter. I did this to a 7060 and it may help you. Can't get it to pull up here for some reason.
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8356 |
I recently done one on a 6080 with a newer high torque and thats the way to go, the rebuild on an old style is 3/4 the price of the new one- just my expirence,
Joe(IA) ![]() Bronze Level ![]() Joined: 12 Sep 2009 Location: United States Points: 99 |
Just put a new gear reduction one on two days ago from carroll implement here in north central Iowa. $530. Turned it over well and suppose to have more torque. A lot easier to put on also( bolt on block side of starter I could get a socket on the new one, not my old one).
JohnColo ![]() Orange Level ![]() ![]() Joined: 03 Apr 2020 Location: Niwot, CO Points: 1263 |
I put one on my Ford 555 backhoe last spring, it spins it over so fast it hardly has to run. Will see how it does in the cold but so far I'm very pleased with it. I found it on the internet, about $100. Hard to beat that price.
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8628 |
Put a new Delco reduction on the C15 two yrs ago. A little over $300 from the starter/battery store.
JC-WI ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: wisconsin Points: 34337 |
Did it to a 200 couple years ago. ![]() |
NEVER green ![]() Orange Level Access ![]() Joined: 28 Feb 2013 Location: MN. Points: 8568 |
While gear reductions are nice , I sure like the original starters, I have two 8050's 0ne with 11000+ hrs the other 8400hrs and both starters are untouched.
