char-lynn seal kit |
mhankins
Topic: char-lynn seal kitPosted: 07 Sep 2020 at 8:25am |
I am looking for a seal kit source for the torque multiplier on my wd45. So far all I have found are the seal kits for the pump,but mine is leaking out of the lower seal where the steering shaft connects.
Play Farmer
Posted: 07 Sep 2020 at 8:52am |
Measure the seal and you should be able to find one on line pretty easy.
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7568 |
Posted: 07 Sep 2020 at 9:06am |
A local hydraulic shop should have what you need.
Michael V (NM)
Posted: 07 Sep 2020 at 4:54pm |
Try this
Eaton power products No.21122 I ordered this from Force America several years ago, its a complete seal kit, with instructions on how to "time" the gears.. |
mhankins
Posted: 08 Sep 2020 at 8:56am |
Thanks Michael. I couldn't find that part number listed,but I will contact the company. |
Michael V (NM)
Posted: 08 Sep 2020 at 11:14am |
here ya go
mhankins
Posted: 08 Sep 2020 at 3:16pm |
Thank you!
mhankins
Posted: 09 Sep 2020 at 9:38am |
Midwest steering has the seal kits if anyone else is looking.
mhankins
Posted: 10 Nov 2020 at 8:44am |
HELP!! Ok,finally got around to taking the multiplier off and replaced the seals,butt... when I tighten everything down it will not turn. I timed it according to the pics above and tried the spacers in each position.The coupler shaft that goes between the rotor and the out put shaft at the lower part has different thickness splines on either end and I have tried those in each position. This is a series 101 which shows a little difference than the one pictured as to how many seals are used as mine doesn't have the larger orings sealing the case and spacers. Any Ideas?
mhankins
Posted: 10 Nov 2020 at 5:47pm |
Never mind,got it going
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8729 |
Posted: 10 Nov 2020 at 8:13pm |
Want to fess up ?
mhankins
Posted: 11 Nov 2020 at 7:39am |
Put it together from the bottom up instead of the top down. ??? worked
