Ford 7700 Simms pump
NomoreJohnDeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NomoreJohnDeere Quote  Post ReplyReply Direct Link To This Post Topic: Ford 7700 Simms pump
    Posted: 06 Aug 2020 at 1:33pm
I traded for a 7700
I'm giving it a going over and fixing things
Looks as if the injector pump may have been off at some point.  Whether it was rebuilt or not I have no clue.
I noticed there are a couple set "screws" that have safety wire holes but no wire.
I'm wondering what is going on there.  Are they adjusted the way they should be and just not wired, or did somebody jack around with them.
Does anybody know what those screws adjust?  What part of the pump is that and what does it control?
thanks
HD3
Post Options Post Options   Thanks (0) Thanks(0)   Quote NomoreJohnDeere Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2020 at 1:35pm
HD3
injpumpEd View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2020 at 3:55pm
those are hi and low idle speeds. Why are you even worried about them? Remember those pumps have their own oil sump.
Post Options Post Options   Thanks (1) Thanks(1)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2020 at 7:30pm
the full load fuel setting is under that cap on the top of the pump in front of the fuel delivery connections.
Tim NH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2020 at 7:56pm
Might be good to change oil in pump. Are you familiar with doing that.
 Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote NomoreJohnDeere Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2020 at 11:33pm
Yes I changed the oil but thanks for the heads up as some don't know about that.
The top bolt is not touching.  I was wondering if that was normal?  Should I screw it down so it does?
I haven't watched it with the engine running to know if it moves, it does not by hand.
thanks for responding
HD3
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2020 at 6:33am
Move the throttle to full high speed and the top bolt will touch and the bottom one will not be touching. Those are the speed adjustments. as I mentioned the fuel setting is under the wire sealed cap, so the pump setting are most likely correct.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NomoreJohnDeere Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2020 at 8:35am
ok
that makes sense
thanks
HD3
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2020 at 12:21pm
 don't understand why Ford did that. My 545B loader with 301/simms has oil feed from block
This page was generated in 0.219 seconds.
