L3 Cylinder Bars
critter View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote critter Quote  Post ReplyReply Direct Link To This Post Topic: L3 Cylinder Bars
    Posted: 06 Aug 2020 at 12:58pm
I am wondering what you guys think of these bars, are they good? need replaced? I think the combine has noticeably lost capacity. A couple of years ago we turned the bars but I dont feel like it helped any (I think they had been turned before).  Are leading the edges supposed to be straight up and down? Should the teeth be square?
In the 1st picture the left side is leading now
2nd picture the right side is leading now
In the 3rd picture you can see the hooked teeth on the trailing side
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2020 at 2:00pm
Replace.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2020 at 3:00pm
They must have been hard surfaced judging by the hook on the worn side and the rough look. They look a little beat but by my eye.... and I'm no expert.... the leading edge doesn't look bad..... some teeth look smoothed over on the lead edge but 99% look OK to me. What are you threshing? What little I know is dealing with corn and soybeans not wheat and not much with oats.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2020 at 3:38pm
They look like worn out Trimpe hard surfaced ones to me and that top pic looks like center of teeth have hd surf  worn away. Look too far gone to re weld. Trimpe in Seymour IN will be your most economical replacement.
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote critter Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2020 at 3:39pm
We run corn, beans and a little wheat, it's become a battle to find a cylinder speed/cylinder height that gets the corn off the cob without grinding the crap out of the corn. It got me thinking maybe the bars had to much wear, the dealer doesn't have any in stock to look at/compare to.
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2020 at 5:45pm
Those bars are shot
ryan
1984 8070 FWA,1979 7060,1975 7040,1971 190,1960 D-17D,1957 D-14, 196? D-19G, 1975 5040,1971? 160,1994 R62
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2020 at 6:57pm
Are those wide spaced bars? Give Bryant Combine Parts a call (south east Indiana) a call to see if they have any salvage bars (anything would be an improvement on what you pictured Confused ). The wide spaced bars made a completely different animal out of the F2 Wink
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2020 at 8:56pm
If you take the time to grind front edge square , they will be better than most bars you can buy today .          MACK
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2020 at 9:26pm
Does anyone know what the depth of a "good useable" bar might be? We've ran across some that had been ran too high or something and took the crown off but still have a lot of meat to them. Just wondered if there was a set discard measurement or if you just go by "feel"
groundhog55 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote groundhog55 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2020 at 7:33am
Those bars look like chrome bars. Replace. You will save money in the long run on fuel.
robb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote robb Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2020 at 8:35pm
Give Oakley Combine Sales & Salvage in Oxford NC a call and ask about the aggressive bars they sell for gleaners. I put a new set in my K Gleaner and am still amazed at the threshing improvement they provide. Phone # 919-693-4367
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2020 at 7:37pm
Seems to me that I called "TRIMPE WELDING" in southern Indiana that refurbishes ALL brands of "bars". They want your bars for a "core" to get the lowest price though.
Edited by FREEDGUY - 08 Aug 2020 at 7:37pm
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote critter Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2020 at 8:28pm
Thanks for all the replies, we are getting a rebuilt set from Trimpe.
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2020 at 8:13am
If the concave is the original one, change it too,with that and new bars,you will not recognize this new machine..
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote critter Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2020 at 10:15am
Yeah I wondered about the concave also, I assume it's original. How can you tell when it's worn too much?
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2020 at 5:34pm
To those that run/ran M/L series machines, how is/are the concave area different than a K/F series ? Are they not a series of bars around the cylinder ? I have no experience with the big conventionals Smile . Thanks
Well, I looked on the APB site (which has changed a little Wink)  And see that there is NO comparison LOLLOL !!
Edited by FREEDGUY - 12 Aug 2020 at 6:02pm
old farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote old farmer Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2020 at 6:06pm
K/F are what I call closed concaves. L/M are open concave with a raddle under there that takes the material to the separater raddle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2020 at 6:11pm
Concaves need to be flat and not have rounded front edges. I'll guarantee it's worn in the center and rounded edges everywhere.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2020 at 6:22pm
Was the "open concave" the precursor to the rotaries ?? Is there a "rock door" on the M/L series like an F ??
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2020 at 7:05pm
Rock door is a yes on M and L.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2020 at 9:17pm
I'm guessing the open design was supposed to handle more threshing with less damage? Guess they weren't much trouble if cared for. Many built over the years
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2020 at 5:31pm
Sadly, after looking at the 'SCHEMATIC"  on the APB, I can't see how the crop of any type enters the "OPEN CYLINDER" ??
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2020 at 6:15pm
I'm not sure about open cylinder, but If you're talking about the L/M and the open concave, it works just like a smaller Gleaner (think A through F) except on the smaller combines everything that gets threshed by the cylinder has to get thrown back by the cylinder, past the thresher beater, and onto the separator raddle. This is because the concave under the cylinder is solid.
To gain a little capacity, the concaves on the L/M were made to be open. Crop enters and threshes exactly like on an A-F, but instead of everything getting thrown back by the cylinder, some of the threshed material falls through the openings in the concave and falls onto the thresher raddle (the A-F combines do not have this extra raddle) The thresher raddle then conveys the threshed material to the separator raddle, where the material joins up with that which was thrown back by the cylinder.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2020 at 6:36pm
Thanks Creston, and yes, I meant open convave . In the parts book, it looks like the cylinder of an L and M series is wrapped with the "concave" much like a rotor ?? I will study the "concave/cylinder " sections some more Wink . Your description is making sense, but to gain "capacity", I assume there are more moving parts involved ?  I was always intrigued with how the L/M series loaded the tank from the r/h BOTTOM of the tank with the floating inner auger that raised the bin extensions Big smile . Ingenious !!!
Edited by FREEDGUY - 13 Aug 2020 at 6:37pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2020 at 9:30pm
for you all's with them series, yes a new concave will make all kinds of improvement+ the new bars...
Thanks Creston for explaining the 'open concave' system on the L/M
Edited by Michael V (NM) - 13 Aug 2020 at 9:31pm
This page was generated in 0.391 seconds.
