D17 diesel liner protrusion fix?
Wes (VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes (VA) Quote  Post ReplyReply Direct Link To This Post Topic: D17 diesel liner protrusion fix?
    Posted: 17 Jun 2020 at 9:07pm
My 17 is in need of this. Just wondering how its done? New liners and cut the counterbore wider? I dont remember a lot of space between counterbores for this last time I had the head off.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2020 at 9:25pm
Surface block then recut counterbore. My fire rings will stop that problem.      MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes (VA) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2020 at 12:28pm
Ok, what gaskets do you use your fire rings with? I put one headgasket on where I had to put fire rings in the gasket. Ive put 2 headgaskets on this tractor. The last one I could see the difference in sleeve height, but like a dummy slapped a new one on and went. I suppose new sleeves are in order to make all this worthwile.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2020 at 12:37pm
The original fix from A-C was so sell you new sleeves that had a top flange that was .030" taller/thicker than the original sleeves. You counterbored the block deeper so these new sleeves would stand out at the correct height. This of course meant a complete engine teardown to the bare block to do this.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2020 at 9:37pm
The Agco, unless the newest have changed. How deep have they sank? If not too much, these MIGHT hold. Measure the thickness of fire ring that failed.       MACK
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2020 at 5:39am
I have to do my 19D too. I need to get a set of "MACK" fire rings
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2020 at 5:42am
So MACK, when resetting the counterbore, do you recommend the .002 protrusion like the manual calls for, or should you jump to like .004?
1968 D15D,1962 D19D
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2020 at 6:32am
Two should be enough.        MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2020 at 10:15am
How do you want us to contact you to order the fire rings
1968 D15D,1962 D19D
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2020 at 9:28pm
Send a PM or call 660 663 9173.        MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes (VA) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2020 at 7:07am
When I get a minute, ill pull it down and check it out. Got your number saved.
brettssac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brettssac Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2020 at 12:07pm
Mack’s fire rings work thanks again mack
BX2,IB,WC,D15IG, D15IIDX3,D17DI,IID,IIID,IVD,D19DX3,D21II,HD3,185,AND GOD ONLY KNOWS THE EQUIPMENT
