Allis 8010 with PD 5 speed
TimZ(TX) View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimZ(TX) Quote  Post ReplyReply Direct Link To This Post Topic: Allis 8010 with PD 5 speed
    Posted: 15 Jun 2020 at 10:35am
Found a 8010 2wd with PD. 4500 hours. Has 5 gears, so they're calling it 20 speed. They are referring to it as a partial power shift. I know it has the high /low and has a left hand toggle switch for another range? Would this be comparable to a powershift? It looks to have a lot speed choices. As I stated in my other post I do hay and have never owned a power shift tractor but most people say the PS is the way to go.
Tim
2-B's,CA,D15,D17,160,2-185's 8010
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2020 at 10:52am
It's not really like a powershift. The hi/lo within 1 gear selection is the only thing that can be shifted on the fly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2020 at 10:57am
Imagine a 185 with 10 speeds on the gearshift and no neutral on the Power Director clutch handle.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2020 at 11:42am
It’s honestly a step backwards from a D17.
Edited by victoryallis - 15 Jun 2020 at 11:43am
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2020 at 12:12pm
i have a real dumb question , if it has a five speed main and a hi -lo that equals 10 where is the other 10 speeds
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2020 at 12:17pm
7000 and 8000 series have a 5-speed main transmission, a 2-speed HI-Low range transmission, which makes 10 speeds. Then you combine that with a HI-Low power director clutch that makes 20-speeds.  Mr. Victory is still farming with a D-17 I guess...…….
allisbred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2020 at 1:18pm
How many gears/speed ranges do you have between 3.5-7mph without having to stop?
Edited by allisbred - 15 Jun 2020 at 1:21pm
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2020 at 1:24pm
For today's farming I'd take one 7050 PD before ten D17's but that's just me.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2020 at 7:24pm
If it was the 80’s and I was buying a new 8000 series the discount for a PD would have to be significant before it would be tempting. I sent my 7080 down the road because I hated shifting it.
tomNE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomNE Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2020 at 7:43pm
2 gears between 3.5-7mph.   i'm up to date on the 7000 series but not 8000 but someone will have that knowledge.   I loved my PD.  the theory behind the AC PS is bullit proof but the speed selection sorta sucks.   I owned a 7020 PS and loved it on the loader.  field work, not as much but then i never baled with one.  I baled with a 7000 red belly and loved that tranny!   In fact they had alot of great ideas on a 7000 series red belly but had some ty ideas also!
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2020 at 8:48pm
We have 2 8050 ps and an 8010 ps. It has 6 forward and 1 reverse in 2 ranges. You can start in either range in 1st though 4th. After your moving you can shift up or down through all six gears, 1st up to 6, 6 down to 1st or up and down as needed without touching the clutch pedal. If you want to shift to reverse, you must come to a stop to shift, but it will not grind, it's all hydraulic. You have limited gears in the work range, yes. I plant corn with an 8050 2wd, I run in high range, 2nd gear and shift down to 1st for ditches and ends. I plant beans with the fwa 8050. This I run in low range, 5th gear and keep the the rpm's up for the hydraulics. But I can shift down to a crawl for going up hills or through draws.
The pd trans does give you a better gear speed selection but once you pick a gear you can only shift either up or down one gear without stopping, clutching and shifting.
If you're using a 185 now, going to an 8010 would be like going from a Ford Maverick to a Mustang. An 8010 with ps trans even better.
Hope this helps.
Good luck
,Leon B Mo
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2020 at 9:21pm
We have an 8070 FWA ps 8050 ps and 8010 ps. We have hills hollers and ditches. It’s nice to be able to go from 1.5 -7 mph without clutching. The 8070 does all the tillage. 8050 pulls a 13’ discbine and I plant,spread fertilizer and brush hog with the 8010. I love the power shift. I have driven PD tractors and they would be fine if you have long straight flat roads and fields. But here I want a power shift.
