AC 160 mower help
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: AC 160 mower help
    Posted: 22 Apr 2020 at 9:25am
I need to know a couple of dimensions of the PTO shaft of an AC 160 3 point mower. I want to know the length of the PTO shaft halves from the center of the cross on each one. Trying to make up a shaft from All Crop combine. Total length from end to center of cross is what I need. The manual gives a length, but i have no idea fro where they measured. Mine will have slip clutch at gear box end. Any help much appreciated. Thanks tracy
garden_guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote garden_guy Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2020 at 10:01pm
I have a mower but not sure how I'd measure it for you as it has all the shrouds and covers on. I also have the manual, but sounds like you do too.
Were all manufactured versions of the 160 the same like mine?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2020 at 10:16pm
Garden-Guy, I have a mower like that also. The PTO shafts are different. I need the ones for a 3 point hitch, not the trail type mower. They are also different lengths for the 160 and 172 mowers. The manual shows the lengths, but no reference to what is measured. Thanks Tracy
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2020 at 6:08am
I have a 3pt AC cutter for parts actually its complete deck is just rusted can't remember if its a 5 or 6 ft.Has the complete shaft,can't imagine there would be much difference in the
two shafts.
Steve Bright View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve Bright Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2020 at 8:00am
I need a shaft and shield just like the 1 in the picture, Mine has a long shaft straight from the gear box.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2020 at 8:48am
two shafts.
Gary, sent you a PM. Thanks Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2020 at 5:47pm
Tracy, just happened to remember your post, today, as I passed by the old 160...  And I happened to have a tape measure, too!
Rear(male shaft), from the center of its U-joint bearing, 18-1/2"  Front (female shaft), same measurement, 28".
This is the factory shaft, on the factory mower, with the clicker clutch, and the rattle clutch, on the rear half!Wink
Edited by DiyDave - 23 Apr 2020 at 5:49pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2020 at 8:31pm
Dave, I will look at my parts and see how they look with those dimensions. Thanks Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2020 at 5:05am
Tracy, if you post a picture of the rear half of your drive shaft, I might be able to tell if it is the same set up, as the one I have on the OEM 160 drive line...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2020 at 10:16pm
Dave, I can text you a pic of what I have. Send me your number via PM. Thanks Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2020 at 5:48pm
Tracey, I texted you the closed length, today.  31-31-1/2", closed length, bearing ctr to bearing ctr.  I may have omitted saying, mine is on a snap coupler OEM machine, with the ORC, at the gearbox, and integrated into the rear U-joint.  It also has the rattle clutch, at the back end of the male(rear) drive shaft. The rattle clutch adds no length to the rear shaft. However the clicker ORC might add about 3-4" to the length of the shaft, coming from the gearbox.HTHHug
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2020 at 8:30pm
Dave, thanks for the info. I will put it to good use. Thanks Tracy
This page was generated in 0.111 seconds.
