Fence row D14 |
Post Reply | Page 12> |
Sugarmaker
Orange Level Joined: 12 Jul 2013 Location: Albion PA Points: 8170 |
Posted: 05 Jan 2020 at 5:41pm |
Folks,
My friend Matt pulled this tractor from a fence row a couple months ago. Its rough, but functions. He belted it up and buzzed some wood with it yesterday. Today was a conversion to 12 volt alternator and coil, and battery. Also he worked on the 3 point hitch system. He got the arms with the pivots from another of his tractors (English Massey). Some pictures: Serial number- D14 5868 Matt installed the tool box that was on one of My Uncles tractors: Both rear fenders are rough with crinkles and the left one was welded where it had rusted out at the bottom. Seat is in pretty bad shape but like the fenders still hanging in there! Where are the brakes on these? Inside the trumpets? Still has some brake left. This rim is not good but has had some repairs around the valve stem. Power director has good snap. No guard on the PD lever indicating a early model too Will WD rims fit on a D14? Added a angle and pins for the three point: Top link bracket assembly fabricated: Regards, Chris
Edited by Sugarmaker - 05 Jan 2020 at 5:47pm |
john(MI)
Yes, The WD Wheels will fit on the D14. Any 8 bolt rim should fit.
Orange Level Access Joined: 11 Sep 2009 Location: Gambrills, MD Points: 50743 |
Re the brakes, they are inside the axle housing, real close to the diff. You have to pull the FD housing, then the axle housing, to get to the brake drums and shoes...HTH
Sugarmaker
Thanks John!
I am working on him to do some horse trading! Maybe bring it to my house and leave it for a while. I mean he does have my TD6 dozer at his place!:) Seems only fair and he is a IH guy! I am going to have a real nice set of Firestone 13.6-28's from the WZ, that would bolt right on this D14! Regards, Chris
Sugarmaker
Dave,
Thanks! So are they of similar difficulty to change? Compared to a WD series tractor? Regards, Chris
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21665 |
looks like nice rubber ! so find some combine rims ! I KNOW they fit !! Yes, brakes are 'inside'..if you want practice...hint,hint.... There's an axle seal that goes,allows diff oil to 'lubricate' the shoes. Also the ram cylinder seals can go or the hyd hose inside the diff. The telltale is having to add hyd oil.... If you open it up for that, have a hyd shop make the hose WITH 1 swivel fitting, it'll make reassembly go easier as the AGCO part(still on my shelf) doesn't swivel...
Alex09(WI)
Orange Level Joined: 15 Mar 2012 Location: CECIL WI Points: 1699 |
No, they are far easier to change. You need a hoist to hold the axle housing, with or without the tire attached, when you slide the axle housing out of the trans/differential housing. 4 bolts hold the axle to the transmission. No rusted brake pins to mess with. The brake drum will stay with the axle in the axle housing. The 2 brake shoes will be attached to a plate that stays on the trans housing similar to the drum brakes on 80's/90's trucks. Once you have the axle off it will be practically self explanatory. Be sure to change the axle shaft seal when you have the axle out.
www.awtractor.com
DennisA (IL)
Orange Level Joined: 11 Sep 2009 Location: Ridott IL. Points: 2064 |
The 28" wheels was a factory option.
Thanks & God Bless
Dennis |
DSeries4
Orange Level Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7232 |
Late model D14s do not have the guard on the hand clutch button either. Nice straight tractor there. She should clean up nicely.
Sugarmaker
Folks,
Matt needed some chains and some help today with his D14. I supplied him with some very worn tire chains that had been used for many years on WD's. When we started looking the spin out rims were not out away from the fenders far enough so we spent a hour or more getting the three eccentrics per wheel loosened and he made some plates for wheel stops. Stop for wheels, add ed both sides on the rail. plate with bolts through them. Looked like this farmer fix was going to work ok. Installed the chains then cut some off each to fit the tire. Some bungees and it was ready to plow snow. He said it worked much better with the chains! Regards, Chris |
Boss Man
Orange Level Joined: 03 Mar 2018 Location: Greenleaf, WI Points: 611 |
Nice Tractor. Looks like something I would drag home.
john(MI)
Is that the type of chains that will tear chunks of the cleats off of the tires? Or does that only happen if they are loose?
Dave(inMA)
Orange Level Joined: 12 Sep 2009 Location: Grafton, MA Points: 2395 |
Nice, Chris. It's always fun to watch you reclaiming another old AC!
Dave
WC, CA, D14, WD45
Sugarmaker
John, Guys,
Yea this is rough around all the edges, smokes some on start up. But it still moves and functions.
I have run these old chains some and they didnt seem to bother the tires. They are so worn and smooth or maybe sharp in some areas. He was happy to get them, We spent some quality time getting those rims moved and the chains on. All in all a good couple hours. I beat on the heads of the eccentrics with a 10 lb sledge several dozen times which may have helped too? I was very surprised that we got the eccentrics to turn. It cost a cheap socket and a 1/2 inch ratchet before they all moved. I told Matt he was pretty lucky as these typically have to be removed from the tractor. He should buy Loto tickets! Regards, Chris |
ACinSC
Orange Level Joined: 16 Dec 2015 Location: South Carolina Points: 2603 |
Gotta wonder if a 3/4" socket fit the eccentrics ? My D 15 seems to be 25/32 . Never did find out for sure . Thanks
IBWD MIke
Orange Level Joined: 08 Apr 2012 Location: Newton Ia. Points: 3499 |
On those eccentrics; I have a (I think) 20mm 1/2" drive socket welded to a 3/4" adapter. Works good on those extra tough ones!
Dave(inMA)
My CA has 1/2" square eccentrics. I welded two 1" six point 1/2" drive sockets together with the square 1/2" drive openings facing out...one end for a breaker bar, the other for the eccentric.
WC, CA, D14, WD45
ACinSC
If memory serves , I think it was 21mm and 25/32 I was looking for . Was hoping to buy one locally and if it didn't fit return it . Of course I can get them online . No big deal , I just wanted to remove them for some paint . Thanks
chaskaduo
20mm is .78739 in 21mm is .82676 in 3/4in is .75000 in 25/32in is .78125 in
HTH
ACinSC
Well heck ! Maybe it was 20mm I was looking for . Thanks Elliott
Clay
Orange Level Joined: 11 Sep 2009 Location: Udall, Kansas Points: 8930 |
I use a 20mm impact socket to turn the eccentrics
TimNearFortWorth
Orange Level Joined: 12 Dec 2009 Points: 2014 |
Rails do not look like the eccentrics were run loose as the rails will show "flattening" of the metal. Have removed eccentrics that were worn paper thin and one old D15 I picked up had rails worn beyond use on both rims as ran far too long allowed to move.
A clunking sound is usually a dead giveaway on worn eccentric inserts but finals low on fluid will cause the same clunking sound.
Steve in NJ
Orange Level Access Joined: 12 Sep 2009 Location: Andover, NJ Points: 11591 |
Great! Another fence row save! Way to go Chris n' Matt!!
EPALLIS
Orange Level Joined: 12 Sep 2009 Location: Illinois Points: 1118 |
Almost hard to believe this is a "fence row find". Thanks so much for saving her, we need all the A-C's we can get since they stopped making them. Keeping her running is the best thing to do. Thanks again!
Sugarmaker
Guys,
I am a little worried about Matt! He is 20 and already has 23 tractors! At this pace he will need more storage soon! Regards, Chris
chaskaduo
Maybe wife would say 11 1/2 tractors.
jollymon68
Bronze Level Joined: 02 Jun 2014 Location: georgia Points: 184 |
Matt... Nice find! I just found a stuck in the woods D17 Series IV. That puts my total at sixteen tractors, not counting the off color ones. Don't let anyone tell you twenty is too many. LOL
Sugarmaker
Guys,
I will let him know that you approve of his tractor hoarding! I think with less young guys that are interested in tractors, they will have to step up like Matt and just have way more than normal. Wait, whats normal?:) Regards, Chris
Sugarmaker
Folks,
Matt came over today with the D14 to borrow my buzz rig to cut slabs. Well it did not go as planned! When we had the top link in place the buzz rig tipped way back. We had to use a short chain to get the buzz rig high enough that he could load it. Luckily he has another 20 tractors to choose from so he mounted it on a 9N and it worked fine. PTO was too short too? Not sure what is going on with the geometry of the new 3 point we put on the D14?? Regards, Chris Edited by Sugarmaker - 31 Jan 2020 at 5:19pm |
Looks like the 3 point is a hangin pretty far back, there...
