newer electronic cutout relay
Ewhitford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ewhitford Quote  Post ReplyReply Direct Link To This Post Topic: newer electronic cutout relay
    Posted: 14 Apr 2020 at 9:57am
Bought a new electronic cutout relay from DJS tractor parts.  Stupid question but before I go hooking this up has anyone else ever used ones of these ? I am in need of redoing my electrical system.  Love the mice.  Since I am I will also going back to the original light switch.  It pulls in and out fine,little dusty/dirty.  Replaced the field resistor with a new one.  As for the wiring do I wire everything up according to the diagram in my book.  The only difference is my WD has a distributor ignition and not the magneto.  Any tips tricks or anything else I should do when I rewire this ol working gal up so she runs.  Thought about just splicing and taping the wires but I figured I might as well do it right. I have a new wiring harness from DJS as well(not the real expensive on. just the basic)  Bought a real expensive one before and the wire coverings just did not last. is there a more complete wiring diagram that shows wires on the gennie as the book shows 2 wires but I have 2 post on the new cutout and 2 post on the gennie.  Just wanting to do it right as so I have no issues. Trying to keep her in somewhat a original looking order. She is a working show tractor in all her glory. Sorry for the novice questions.  I have rewire her once before but just curious if anyone has any better/easier lasting ideas.
Thank you.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2020 at 5:38pm
If it's like this one, the cutout should be marked.  Short wire goes from A terminal on generator to A or Arm. terminal on cutout.  Harness wire from there goes to Ammeter.
Second harness wire goes from F terminal on generator to resistor terminal on headlight switch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ewhitford Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2020 at 8:05pm
Thank you.
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2020 at 11:58am
It is  a diode in a box and filled with epoxy. I had one go bad but the others I have are good. Just follow the directions.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2020 at 2:39pm
IMHO, if a cut-out needs replacing, it's a great time to change it to a voltage regulator. You will also need to change the light switch to a simple on/off switch.
It's a great modification to a 6 volt system!
