7040 Powershift Parking Cable
Red Bank View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Topic: 7040 Powershift Parking Cable
    Posted: 24 Mar 2020 at 7:43pm
Tractor won’t go in park. We pulled floor pan and tried to lube up cable and work it back and forth. I think I need to replace it does anyone know the Agco number for the cable or recommend aftermarket resource?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2020 at 9:10pm
Make sure the small cable is moving shifter far enough.      MACK
210Postin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 210Postin Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2020 at 9:13pm
have cables instock for everything on that tractor
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2020 at 7:25am
I just got a 7040 with the same problem. I put new cables in as suggested. It shifts much easier but still wouldn't go into park. The short cable I could not shorten enough to pull into park.
Look at the area I circled.
The curved link is moved when you put shift lever in the park gate. That curve area was extremely worn so I took it out and built it up with a few passes with the welder. Goes into park much easier now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2020 at 7:38am
An area that needs some spray lube shoved down in there a couple of times per year.
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2020 at 7:48am
Good idea. Chain/cable lubes?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2020 at 9:16am
Anything is better than nothing. Chain lube probably stays longer.
