190xt
festus51 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote festus51 Quote  Post ReplyReply Direct Link To This Post Topic: 190xt
    Posted: 10 Mar 2020 at 3:39pm
I'm going to have to overhaul the engine in it.   I want to do an in-frame.  My question is will the oil pan come off with out having  to remove any major components?    It is raining and I don't feel like getting wet to go look at it.
Thanks
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2020 at 8:13pm
IIRC, the 'wishbone' for the front axle will have to come off,,,I'm not sue about this,,going from a weak memory, been a long time since I had a 190....
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2020 at 8:19pm
Yes, the front axle needs to be removed.  Can't drop the oil pan with the axle in place.  Having said that, I would recommend an out of frame rebuild.  I strongly suggest replacing the cam bearings too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2020 at 8:22pm
Wishbone and front axle I would think would need to be rolled out. I had to drop the wishbone and it’s rear brace and raise the frame just to change my oil pan gasket.
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2020 at 9:51pm
Yes, ike others have said, the frontend needs to be rolled away to remove the oil pan. By the time you do that, another 10 min and you could have the engine off the torque tube for an out of frame rebuild. If you do that, you can inspect the clutch, flywheel, relace rear seal, and replace torque tube input seals, throwout bearing/pilot bearing.
www.awtractor.com
A&W TRACTOR 920-598-1287
Post Options Post Options   Thanks (0) Thanks(0)   Quote festus51 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2020 at 7:39am
Thanks for all the replies.  I never like the idea of crawling under tractor with out the axle attached.  So it will be out of frame and the engine will get the total treatment.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2020 at 8:27am
Never worked on one but from what I hear be real careful about the liner protrusion and fit.       Leon
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2020 at 6:03pm
Technically when the front end is rolled away there is only 1, 1/2 in bolt holding the motor to the rearend  so always a good idea to support it when you get that far.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2020 at 8:43pm
Not a real problem on these engines.  Sleeve protrusion is an issue for the older diesels:  230, 262 and 175 cubes.
youngorange2000 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2020 at 1:42pm
I have taken my oil pan off whit out removing the axle completely, I did my in frame that way. I had to jack up the torque tube (using a 6x6 oak block between the jack and the cast housing) intel the front wheels were just off the ground. Then I used a floor jack and wooden block to lift the very back pivot point of the axle just enough to remove the big bolt/pivot pin then when the jack was released there was enough space to get the pan out. IIRC I had to slide the pan forward some then spin it 90* and it slid out no problem. And the oil pump came out no problem with the axle still fully attached at the front. That was my experience with it
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2020 at 3:22pm
I've done the same too..... way back at the dealership.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2020 at 3:48pm
By the time you get done wrestling out six sleeves, six piston/conn rod assemblies, 7 (x2) main bearings, etc, etc, you'll wish you'd have taken the time to just roll the front axle ahead four feet and get it out of the way. Before you do anything, dump 2 gallons of diesel fuel into the crankcase and let it run for a few minutes before you drain it and take the oil pan down. You'll like how nice and clean it is inside after a diesel fuel bath.
