Help Wanted - Rear Wheel Bearing |
mas123mas
Bronze Level Joined: 10 Feb 2020 Location: United Kingdom Points: 3 |
Posted: 10 Feb 2020 at 12:49am |
Hi All, New to the group, as I have just purchased a 1948 Allis Chalmers B, that need a little work.
I am needing two new Rear Wheel Bearings, has anybody a make / part number for these, or the sizes and description. I am wanting to order the spares before I remove them ideally. |
Mikez
Orange Level Access Joined: 16 Jan 2013 Location: Usa Points: 8182 |
Thanks(1)
Welcome to the forum. There's some good info on here. Post this question over in the farm equipment section for better results
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 78398 |
Thanks(1)
Rear Axle/Final Drive:
Axle Seal- CR #25043 Axle Speedi-Sleeve - CR #99248 Outer Axle Bearing Cone - Timken #368A Outer Axle Bearing Cup - Timken #362 Inner Axle Bearing Cone - Timken #14138A Inner Axle Bearing Cup - Timken #14276 Bull Pinion Seal: CR #13900, National #450456 Bull Pinion Bearing Cone - Timken #14138A Bull Pinion Bearing Cup - Timken #14276 Transmission & Differential: Differential Carrier Seal - CR #11343, National #410163R Differential Carrier/Bull Pinion Speedi-Sleeve - CR #99125 Differential Carrier Cup - Timken #25520 Differential Carrier Cone - Timken #25580 Input Shaft Cup - Timken #15250 Input Shaft Cone - Timken #15120 Input Shaft Seal - CR #11800, National #450162 (471765) |
Ted J
Orange Level Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18743 |
Steve, are these the same for the 'C' ?
as far as i know the B and C use the same bearings in all locations...... above is what i have used on the B.
mas123mas
Many thanks.
I have now ordered the parts.
