paint off of old tractor rims |
Roundman
Bronze Level Joined: 06 Mar 2011 Location: Baldwin City.Ks Points: 67 |
Posted: 26 Jan 2020 at 5:40pm |
Is there any easy cheap way to remove paint off old tractor rims.
Sugarmaker
Orange Level Joined: 12 Jul 2013 Location: Albion PA Points: 8170 |
Several things come to mind.
Sandblasting may be the best. it may cost you up to $100 for a pair. I like to have the tires removed and then blast. It can show if the rim has any weak areas too.
I got a pair done for $50.00 a few weeks ago. Electrolysis process is very low cost but the set up to have a tank that big may be prohibitive. Mechanical wire brushing can work too. Also paint removers can loosen a lot of old paint. Regards, Chris |
Orange Level Access Joined: 14 Sep 2009 Location: Hermann, Mo Points: 29836 |
A lot of shops have switched to Soda Blasting to get away from Silica Poisoning issues, we used Black Magic agent which was basically Coal Cinders, not a lot of call nor people to do this around here anymore.
john(MI)
I had a pair blasted with centers and the eccentrics all included. I had them all disassembled so they had lots of small stuff to do. They were doing big dump trucks and the rear axle area of road tractors. Couple years ago now, it cost $150 if I remember correctly. I was very pleased with the job.
Clay
Orange Level Joined: 11 Sep 2009 Location: Udall, Kansas Points: 8930 |
If you have an old stock tank, Line it with 6 mil plastic sheeting. Fill with your electrolysis solution. Put a plastic grid in the bottom to hold the rim off the bottom. Hook up the wires and such.
johnkc
Orange Level Joined: 22 Sep 2009 Location: KCMO Points: 714 |
I have used A1 Paint Powder & Sandblasting in KC with great results
I support the development of hybrid automobiles and alternative fuels as I need DIESEL fuel for my ALLIS CHALMERS!
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21665 |
'blasting' is faster but $$$ compared to electrolsys, depends on what you value time or money.
ac fleet
Orange Level Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2226 |
Burn them off! --- Watch how long you leave them in the fire. I saw a guy do this one time, after the burn he wire brushed them, then washed them good. Didn't seam to hurt the rims any. I use a big body grinder to clean them. There is no easy way to do it and any way is going to cost money.
