AC Hay Conditioner
bigbird View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigbird Quote  Post ReplyReply Direct Link To This Post Topic: AC Hay Conditioner
    Posted: 11 Dec 2011 at 8:19pm
Does anybody have any information on a hay conditioner, we called them crimpers.  My son found one in some weeds at a neighbors who was giving him the scrap for cleaning it up.  It clearly has an Allis-Chalmers decal on it, but cannot find the model or any ID plate.  I thought it best to scrap, but he loves anything Allis.  So we took it home, put ne tires and a new chain, with about a can of penetrating oil, filled the gearbox.  Lo and behopld hooked it up and ran great.  It has a smooth rubber roll, and a notched steel one.  A post on ebay lists a model 25, but we just don't know.  Who knows a little paint and we might have something.  Any ideas?  I can't find anything in the Agco on-line books, and dealer doesn't have anything.  Thanks
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2011 at 8:45pm
   AC made a hay conditioner from 1960 to 1970. Your description describes this machine. It had 6 foot long rolls. It did not have a model number from what I have read.
http://www.rumelyallis.com
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2011 at 9:08pm
thay made a 904 one of the later models
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2011 at 9:42pm
   The 904 is a mower-conditioner.
Bill(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2011 at 12:51am
I have an original operator/parts manual and there is no model number shown. The only option was a hyd. lift att. It also shows an improvement pkg shipped to dealers for models up to 1101.
Should be a serial no. stamped on R.H. side plate.
Bill(MO)
Armand(AZ) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Armand(AZ) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2011 at 6:36am
The hay conditioner didn't have a model number to my knowledge.   I built a model of one and have the manual.  You can see the model on my website for comparison:   acmodelsofarizona.weebly.com
Armand
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2011 at 7:08am
I,ve pulled one over many,many acres with Farmall H tractor. They are OK in short hay,but in tall orchard grass or fescue it will constantly wrap the steel roller.  You will need a SHARP knife and tons of patience. I know it is AC,but in my opinion they aren't worth TWO DEAD FLIES. This is one machine that would even make the pope cuss.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2019 at 9:41am
Found this old post and actually went to look at one the other day. Unfortunately it has a bent pto shaft. Does anyone have a measurement for a pto shaft? Not sure if Tractor supply has one the correct length?
michiganmarty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michiganmarty Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2019 at 8:18pm
we ran one, and yes it tried your patience at time, if the divider board work on the mower, it worked ok, but if it wasnt didided clean it would plug on the end, and would need to be cut out.  i think the roll was worn, and that why it did that.  it worked better the newer it was.  Did help dry the hay though, maybe a day or day and 1/2. earlier.
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2019 at 8:50pm
I still use one! I’ve never had it wrap up yet and hope that it doesn’t. It does work well.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2019 at 9:21pm
Dennis, can you get me a length on the pto shaft on yours? I have seen your video and it appears to work well.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2019 at 7:45am
That’s got to be one of the most amazing posts I’ve ever seen! Never? Wow! We used one way back in the way back days. Also had a New Idea. They both plugged plenty!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2019 at 9:49am
Wow that is something. We always thought it was certain types of hay that wrapped or not. Some fields didn't give us trouble an some did every time. I had an axe laying right on conditioner and when it wrapped would cut through the wad then take it to the nearest woodchuck mound or any other mound and drive over it, that would turn the bottom roll an turn the plugged hay out.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2019 at 4:36pm
Checking with Pop's 1960 Price Book there is a hay conditioner listed.
PTO Driven Includes 72" Upper rubber covered roll, 72" lower staggered bars on solid steel tube, hand lever control, two 13" discs and rims - less tires, slip clutch  Enclosed Gear Box and  Roller Chain Drives
Hay Conditioner - less tires    $ 740.00
5.90 - 15" Tires - rib implement  $ 50.00
Hydraulic Lift Attachment - $ 16.00
Good Luck!
Bill Long
Hey Armand,  Is there anything Allis Chalmers that you DO NOT have a model of - including Pop's Dealership O. E. Long & Son
Edited by Bill Long - 28 Dec 2019 at 4:38pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2019 at 8:05pm
Hey bill here's a picture of a purchase statement from my grandfathers dealership. It's heading is. Allis-Chalmers manufacturing company. Syracuse, New York
In the middle is hay conditioner
Oh here on the second page he got two in 63
I'll have to look SR number of the one at the farm, one of these went to they're farm an still have in barn
Edited by Mikez - 28 Dec 2019 at 8:22pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2019 at 5:50pm
That’s cool Mike. Great to have the paperwork.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2020 at 9:05pm
Here is the measurement 52.5". That is with the P.T.O. pulled out about 10" as I could not get it slid all the way in.
Thanks & God Bless
Dennis
Steve Bright View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve Bright Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2020 at 8:03am
My Dad bought 1 new in 1961, I pulled it over many acres, Dad mowed hay with a WD 45, I pulled the crimper with a D 14.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2020 at 9:27am
Thanks Dennis, I will see if I can find one at TSC.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2020 at 6:03pm
They'll likely charge you $300 and a 3 week wait, from my experienceWink
Try surpluscenter, at the link, below, they might have one, hard part, sometimes is matching to the machine's end shaft...Wink
Edited by DiyDave - 02 Jan 2020 at 6:08pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2020 at 8:07pm
Thanks, I will check them out
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2020 at 7:21am
Dad mowed with a side mount 80 or 82 and pulled an AC crimper directly behind his WD45 or WD except for the initial round. He mowed mostly straight alfalfa and it worked well but he has said it didn't like grass. Grass around here usually doesn't need crimping to dry fast.
Wink
I am a Russian Bot
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2020 at 9:13am
you might call Sloan’s express located in Assumption IL. A few years back, Brian Sims @ Sloan Express, found me a reasonably priced replacement pto for an older IH 60 flail mower. It has been a good quality part. Here’s their web link info:
https://www.sloanex.com/contact-us
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2020 at 9:34am
When I worked at the local CaseIH dealer and before that the local AGCO dealer, we just built PTO shafts to customers needs. Had 10 foot long shafts of various sizes and cut to length, grabbed the correct yokes and cross bearing of the shelf and put it together by welding or pinned depending on what was needed or what worked. When I had a bent PTO shaft on my Duetz-Allis discbine I just removed old shaft from yoke went to the CaseIH dealer and they cut me off a chunk of metric shaft and I put it back together. Can't remember if it was held together with a roll pin or if I welded it together. Worked fine.
Wink
I am a Russian Bot
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2020 at 12:20pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2020 at 1:21pm
We could never get the simultaneous pull to work worth beans.  Just wasn't lined up good enough, and made the plugging nightmare 3 x worse.
This page was generated in 0.254 seconds.
