D17 Series 1 hydraulic
JimP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimP Quote  Post ReplyReply Direct Link To This Post Topic: D17 Series 1 hydraulic
    Posted: 25 Dec 2019 at 3:27pm
I just purchased a D17 series 1. My question is can I mount a new style hydraulic pump on this tractor?
Thank you much
Jim
JimP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimP Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2019 at 4:09pm
Forgot to mention I want to run a haybine with it so I need to lift the machine
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2019 at 6:07pm
You can use the hydraulic outlet on the transport vale if it is single acting
A front mount pump like used on a loader can be added along with a two way valve for independent remotes.
rw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rw Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2019 at 6:10pm
A series one should be fine with a single acting cylinder on a haybine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2019 at 6:14pm
Single acting cylinder is all you need as header reel weight will be enough for it to lower back down without having a 2-way cylinder.
You will need a HP cylinder to match the 17 Hyd Pressure, plus it needs to be single acting or a 2-way that you can set up as vented.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2019 at 7:18pm
If you go with a 2-way valve to the left of the seat, you can operate a 2-way cylinder and it will also be at the right pressure setting of 2,000 to 2,200 PSI and use the internal hydraulic pump. The negatives are the internal pump is only 4 to 5 GPM and will be a little slower on a 2-way cylinder. The internal pump also is dead when you push in the foot clutch, so the hand clutch needs to be used. If you only need one single acting/single hose cylinder to do the job, get one that fits the 3400-3700 psi hydraulic system of the tractor and the raise speed will be fine.
JimP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimP Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2019 at 6:35am
Thank you for the input. Sounds like calling Northern Hydraulics and get a single acting cylinder is the easiest approach. Thanks again for the help. Merry Christmas.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2019 at 6:39am
Just buy a breather plug for the cylinder you have now.  Put it in the hose port you don't need.  Any farm store should have one.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2019 at 8:40am
You will need a cylinder that is rated for a much higher pressure.  Typical new cylinders are 2200 psi.  Early D17 hydraulic operating pressure is around 3500 psi.
JimP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimP Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2019 at 9:10am
Thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2019 at 5:40pm
check out surpluscenter.com, before you buy chinese crap at northern...Wink
JimP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimP Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2019 at 7:02am
Will do thanks
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2019 at 8:26pm
Do be sure you get a HIGH PRESSURE one way ram.
In our day one customer added washers to the unloading valve moving the pressure way up over 3500.  He wanted to make his loader lift more.  He blew several loader rams.  Luckily no one was hurt.
Good Luck!
Bill Long
Edited by Bill Long - 28 Dec 2019 at 8:27pm
