6080 clutch issue |
cowkicker
Topic: 6080 clutch issuePosted: 23 Nov 2019 at 7:17pm |
Having trouble with a 6080 clutch, couldn't adjust cable enough to get clutch to release. Split tractor and didn't see anything obvious, haven't measured anything yet because I just got a book with specs. Question is, if plates and discs are within tolerance, has anybody had any luck adjusting pressure plate fingers. Hate to spend a lot of time and put it back together only to find out that I should have spent $1000 on a new one!
Posted: 23 Nov 2019 at 7:58pm |
Let's start from the beginning. The tractors clutch was working just fine and now it won't release ???
And which clutch won't release?? the PTO clutch or the traction clutch ???
Edited by DrAllis - 23 Nov 2019 at 7:59pm |
cowkicker
Posted: 23 Nov 2019 at 8:37pm |
Sorry wasn't very clear, with clutch pedal pushed down, I cannot put transmission or pto in gear, lots of gear grinding. Have to shut engine off to put trans and pto in gear. Tractor moves when in gear and clutch completely depressed. Don't know much past history of tractor.
DougG
Posted: 23 Nov 2019 at 9:19pm |
Is there a lot clutch material- dust in the bell housing ? I wouldn't move anything on those fingers till you know the cause ; they are fine adjustments between the engine clutch and pto ; make sure the cable isn't binding and working properly
victoryallis
Joined: 15 Apr 2010 Location: Ludington mi Points: 2878 |
Posted: 23 Nov 2019 at 9:28pm |
How’s your crank play?
DougG
Posted: 24 Nov 2019 at 12:17am |
Good call there
Rick
Joined: 11 Sep 2009 Location: Jonesburg,Mo. Points: 3695 |
Posted: 24 Nov 2019 at 5:09am |
Dave...Sent you a message...Rick
