D-17 Muffler |
JD-Ohio ![]() Bronze Level ![]() ![]() Joined: 22 Oct 2009 Location: Columbus Grove, Points: 39 |
![]() ![]() ![]() ![]() ![]() Posted: 17 Nov 2019 at 2:25pm |
D-17 gas serial number 33833. DJ.s and Steiner.s list a muffler for serial numbers less than 32000, and one for serial numbers greater than 42000. But nothing for the numbers in between. What gives?
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21866 |
There are only THREE mufflers for a D-17 gas. The original muffler was the exact same as a WD45, was round, and attached with 2 bolts and was about 3 inches in diameter and this was prior to s/n 32000. The next muffler clamped to a pipe coming out of the exhaust manifold, and was round and about 4 inches in diameter and was prior to s/n 42000. The last muffler from s/n 42,001 and up were the OVAL muffler and is considered a series 3 or 4 muffler. This all being said doesn't mean someone hasn't changed manifolds or cut larger holes in the hood to accept something different.
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8617 |
The oval factory muffler was the nicest. Quiet power.
AllisFreak MN ![]() Orange Level Access ![]() ![]() Joined: 07 Dec 2009 Location: Minnesota Points: 1586 |
Would sure like to find an oval Nelson muffler for a D17 series III. Nearly impossible though. They sounded so nice.
If you find a Nelson to a 180/185, graft that onto a D-17 gasser and you'll love the sound it has with less back pressure. The body is the same size. You just have to make a pipe adapter to slide over the pipe on the exhaust manifold to get things to match up.
Thanks Doc, good to know. I really miss that Nelson sound.
Charlie175 ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
I see Steiner carries the Ovals, how do these sound?
Charlie
Joe(OH) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Montezuma, Ohio Points: 991 |
Here is what I did. https://www.allischalmers.com/forum/topic157965.html
Gary ![]() Orange Level Access ![]() Joined: 13 Sep 2009 Location: Peterborough,On Points: 5899 |
JD Check out Nelson 18202T. They cross reference it to Allis 70261975. Gary https://www.simplyfilter.com/18202t-nelson-global-products-muffler-p/18202t.htm …………………………………………………………………………………………………… or this one 05388t https://www.simplyfilter.com/05388t-nelson-global-products-muffler-p/05388t.htm https://www.simplyfilter.com/05388t-nelson-global-products-muffler-p/05388t.htm Edited by Gary - 21 Nov 2019 at 9:09am |
Thanks for the ideas guys. I'd love to find an oem oval Nelson with the offset outlet like they came with back in '63.
