Loaded 14.9 X 26 tire weight
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: Loaded 14.9 X 26 tire weight
    Posted: 02 Nov 2019 at 5:40pm
Anyone know about what they weigh ? Loaded with water . Thanks
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2019 at 6:01pm
around 650 or more
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2019 at 6:11pm
Would that be apiece ? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2019 at 6:14pm
yes;; each wheel an tire'
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2019 at 6:58pm
Ok , I was wrong again . Figured it added about 1,000 lbs total . Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2019 at 8:40pm
they mite be more' i got a 13.6-28s there around 800 each
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2019 at 8:51pm
Pure water weighs less than calcium chloride. 7 lbs versus 10 pounds of the good stuff. So on 45 gallons per tire that could be 270 lbs difference.  I'd speculate tire, tube and rim to be at least 250 lbs each plus what kind of fluid is in them.
frnkeore View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote frnkeore Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2019 at 12:44am
This is off of a chart that I have:
                                        Gal                Water weight        3½ lb/gal CaCl2         5lb/galCaCl2
14.9-26
48
400
486
520
Frank
1959 D17 Series I #24001+, '59 D14
'55 & '59 Ford 850 & 861
Ferguson TO 35 Deluxe, Oliver 70 and 5 more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2019 at 3:23am
Good info . Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2019 at 8:29am
14.9-26
48
400
486
520
This is correct as water weighs 8.33 lbs per gallon.  As per Firefighter I & II
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2019 at 9:18am
Thanks Frank andTed .
Edited by ACinSC - 04 Nov 2019 at 9:20am
