any H IH gurus
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Topic: any H IH gurus
    Posted: 18 Apr 2019 at 9:13am
We have in the shop a H Farmall - issue , the intake valves stick.  We removed the valves, reamed the guides and issue remains.   Seems no oil is going to lube stems- the rockers only have oil seeping out either side of the rocker - pressure is good.
any ideas ?
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2019 at 9:56am
All the intake valves stick? exhaust valves don't?
'pressure is good' where did you measure?
is there enough oil in the crankcase?
if the oil pan has the 2 'petcocks' on the side, oil must drip out the upper one when it is cracked open.
steelwheelAcjim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steelwheelAcjim Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2019 at 11:24am
Has this H been in running order, or are you getting it to run after a long period of sitting??
Pre-WW2 A-C tractors on steel wheels...because I'm too cheap to buy tires!
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2019 at 12:42pm
owner said sitting a while - we found rocker arms all stopped up - oil now goes to the push rod side but not to the valve side -  #2 and #3 intake only sticks.  We took head off and reamed   the valve guides -plenty of clearance - polished the stems - shimmed the springs - set the lash to .012 hot  and the two intakes still stick.  It might run 15 minutes - then stick.  anytime a load is put on the engine the valves stick.  The head top is as clean as possible - no crud.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2019 at 12:53pm
Also when one sprays lube in on the spring while running - it makes the issue worse.
To unstick , one just has to tap the valve and it will pop back up .
OldAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OldAC Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2019 at 2:29pm
If you have any old gas in the system, it will cause the exact thing you mention - Intake valves only to stick. The old gas shellacs up the stems and sticks them.
Been there :(
Edited by OldAC - 18 Apr 2019 at 2:30pm
Post Options Post Options   Thanks (1) Thanks(1)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2019 at 3:06pm
Drained gas , flushed , added seafoam and another cleaner, fresh gas .  Ran a can of carb cleaner through carb with eng running .   UNIT THEN RAN GREAT FOR 1 HOUR -  pulled  it out of shop and both front 2 intake vales stuck open.   Also have adjusted carb for lean and rich run - no difference.  Kind of a puzzle.
Edited by tbran - 18 Apr 2019 at 3:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2019 at 3:26pm
Everything that shows up here gets Seafoam in the gas and oil. Had a D15II that sat for years, decent oil pressure but less oil up top than I liked. Seafoam tends to clean up gals pretty darned good but I don't leave it in and work it too long for fear of loosening all the crud and plugging up the sump screen.
Usually drop it after 20-30 minutes at op. temp, leave drain plug out overnight, fresh fill and work it before another oil/filter change within an hour or two of using it.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2019 at 8:34am
That's a really good thought Tim, Seafoam the oil side of the problem too!
This page was generated in 0.185 seconds.
