7060 HYD. IMP. QUESTION
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Topic: 7060 HYD. IMP. QUESTION
    Posted: 15 Apr 2019 at 8:29pm
BUDDY'S GOT A J.D. 12 ROW CORN PLANTER WITH 2 PRESSURE LINES AND A RETURN,HAS ANYBODY GOT ANY GOOD WAYS TO HOOK UP THE OPEN RETURN TO TANK LINE ON THE 7000 SERIES TRACTOR'S OTHER THEN DUMPING IT IN THE FILL PLUG HOLE, AT  THE REAR END?
THANKS FOR ANY IDEAS.
DAN
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2019 at 7:06am
Lower sight glass for one place, which is easy to do. The metal cover plate below the PTO and above the drawbar could be drilled and tapped into for a Pioneer coupler off to one side.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2019 at 8:18am
If you're dealing with a vac planter post back how it works out. "They" say 7-8000's don't have enough hydraulics to run one.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2019 at 10:43am
great thanks for the tips.
not a vac system.
dan
D15 SER.2 DIESEL
2-720'S D21 Ser. II
Gmc,caterpillar
210Postin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 210Postin Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2019 at 9:16pm
They will run a single motor, but not two dont leave much to run the rest of planter.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2019 at 10:30am
Thanks for sharing about the Vacuum planter motor issue. What factors contribute to the AC tractors’ issue with this?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2019 at 11:38am
I'm assuming that 23 GPM doesn't meet todays new planter specs. Most modern day tractors are more than 50 GPM and some near 80 GPM's.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2019 at 12:13pm
I don't get it but certainly don't know all facts. Read online somewhere specs on those fan motors taking 4gpm. Is that right? If true,how does that max out hydraulics? Is there not enough left to raise it? I know there are several lift cylinders.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 210Postin Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2019 at 8:33pm
Well a 7200 16 row with two blowers will take around 15 gal just for blowers ,have a pump doc pump on a 8050 ,pto pump cooler and flow controls to run mine .Tractor hyd run lift and markers thats how we run ours.
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2019 at 9:56pm
IF, if you were running GPS and Field IQ to turn on and off the planter, once you cross the inside end row, the meters will stop. If you turned off the valve for the motors, would the seed fall away from the vac plates?
  If not, could you turn off the motor valve, raise the maker(if used) then raise the planter? We run a blue finger pickup planter and I know that doesn't count for much these days.
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2019 at 1:46am
Meanwhile there is a guy in SW KS running a 16 row central fill White with a 8070. :)
He admits he shuts down the central fill blower to lift it on the ends though. Pressure planters take alot less hydraulics to run, much more friendly for older tractors.
Edited by GM Guy - 18 Apr 2019 at 2:04am
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
lentsch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lentsch Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2019 at 9:50am
Yes, seed will fall off the discs as soon as vacuum drops off. I pull a 6 row 1750 JD vac planter with my 8010-works decent, but vacuum drops quite low when I raise and lower the planter, so I don't think you could run 2 vac motors as found on bigger planters. If I need a bigger planter I would use a PTO pump to run vacuum motors or buy a finger planter. IMO a well maintained finger planter works as good as a vac planter. I had to replace a vac motor last year-not cheap.
Edited by lentsch - 18 Apr 2019 at 10:00am
WD,D15,190XT,7000,8010x2,7060,8070
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2020 at 3:52pm
Funny this just came up again, just had a neighbor ask this am if his 8070 had enough hyd to run a 16 row. He has a 12 now but wants to go to 16, would be a White planter, I know nothing about them, just this question.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 210Postin Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2020 at 10:42pm
Well we run a 6122 white bean planter 12 23 with the small pto pump to run the blowers has to be run at rated speed for 2.5 at gauges
This page was generated in 0.445 seconds.
