WD 45 starting problem
Stanley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stanley Quote  Post ReplyReply Direct Link To This Post Topic: WD 45 starting problem
    Posted: 07 Feb 2019 at 9:29am
Recently had trouble starting. (have 12 volt system) Replaced battery, new cables & ends. Actually had starter out and serviced. The tractor will start if I pull it.
I took the starter out yesterday again and tried turning the crankshaft gear with a long punch. It will turn, but with a lot of force.
When I try to start the engine barely makes a groan, sounds like a very weak battery or bad connection somewhere. The voltage from battery to starter drops to about 6 when trying to start.
I think my problem is that something is making the engine turn-over too hard. Any ideas/suggestions?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2019 at 10:30am
What does the starter switch look like? The contact on the starter can wear and erode. The switch contacts can erode also , making a poor connection. I file can fix these contacts up if they aren't too far gone and you can hold your mouth right and keep the angles good for best contact.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stanley Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2019 at 10:41am
It's a push button starter switch that's connected to the long starter rod.
Contacts look okay. I replaced the starter switch couple yrs. ago. I am pretty certain the contacts are clean and secure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2019 at 10:48am
If you 'jumper' the starter switch and it starts nice...it's the 'starter swich', if it doesn't then I'd say battery cables and or connections.
I use premade cables NOT ones where I have to bolt/clamp/crimp/? the ends onto 'raw' cable. You NEED really good connections. How's the battery ground ? clean and shiny with new ,clean bolt and lock washer ??
A 12V battery dropping to 6 means there's a high resistance 'somewhere' in the wiring. 'high' in this case means a FRACTION of an ohm, which you wil NOT see on any normal meter.
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stanley Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2019 at 10:57am
Thanks,Jaybmiller. I give it another "look see" tomorrow. Can't get to the farm today - rain, sleet & snow. Tomorrow just below zero temps.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2019 at 11:09am
Pull spark plugs and use hand crank to rotate engine. If it turns easy then you have eliminated too tight an engine. Starter could be bad and pulling too many amps loading down new battery. New battery could be bad. Did you charge the new battery before use? These are just my thoughts.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2019 at 1:17pm
Agree with Stan.  Could be bent/stuck push rods, valves or even stuck crankshaft bearings.  You've gotta take baby steps and try one thing at a time.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2019 at 2:04pm
he sad it will run if he tows it then engine is ok  take switch off starter jump right on starter post with good battery ground jumper cable to starter
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2019 at 5:22pm
If you're running a 12V system, then you should have the Starter changed over to 12V using a starter relay either mounted on the Starter motor or on the Tractor. First, charge the Battery up, then do a draw test on the Battery to make sure your power supply is reliable. If the Battery passes, I would move to the Starter and have a reliable rebuilder run through it and set it up for 12V w/a relay. Move to a key crank start Ignition switch. Those old mechanical switches are the worst for transferring power, especially running the fast moving current of 12V's through them!  With that type of king size voltage drop, my bet is on the Starter providing the engine is loose and nothing internal is going on with rod n' main bearings...  We offer 6-12V Starter conversions done the correct way if interested....
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stanley Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2019 at 5:40pm
A little more history - I've had the tractor for about 5 yrs. It had the 12 volt sys. when I got it and it always started easily. A few weeks ago the problem started. Thought battery as it was 5+ yrs old. I did charge the new battery and it held a charge, also had the starter out and serviced by a good rebuilder. He said the starter was ok. I have tried going from the battery directly to the starter post and still get a "groan", will not turn over the engine.
Unfortunately this tractor does not have the "pin" in the front for a crank. So, I'm not able to crank it. If I took out the plugs and tried to start, would that tell me if the engine is ok?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2019 at 6:10pm
Yes, It takes compression issues out of the loop.  How do the cables look?  If they are corroded, or too thin, they can heat up, and cause resistance.  Good luck...Wink
allisbred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2019 at 6:20pm
May want to check the new battery for dead cells, I have bought batteries that had a short. My 45 is very tight with the hand crank, don’t think I have enough “** to whip it. Go back to a screw driver to jump starter and minimize all power losses then replace cables and switch. That will be much cheaper than digging in the engine.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2019 at 6:21pm
How is your ground connection from the battery cable to the engine?  Is the connection clean and shiny?  Poor ground is a common problem.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2019 at 8:13pm
Had a new tractor that didn't turn over good. Found cables were corroded on inside. This one could have got sea water in it on boat ride over here.      MACK
wide View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wide Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2019 at 11:11pm
Should turn over hand if you grab the fan belt and fan right?
 I suppose if the clutch was dragging it would allow you to pull start but be hard to start with the starter,..
but wouldn't the tractor jump forward?
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2019 at 6:53am
If transmission is out if gear probably would not notice tractor jump forward when it starts. Are you pushing the foot clutch when you try starting it? Just disengaging the hand clutch still leaves the PTO and hydraulic pump engaged.
You have replaced most of the components in the starting system, so that eliminates that. Like others have said check the ground cable, but also check that the starter is grounding to the bellhousing. Using a battery charger with boost mode, try connecting directly to the lug on the starter to eliminate if the battery, switch or cables are bad. Make sure it is out of gear if you try that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2019 at 11:46am
What problem?  The starter not turning the engine over?
Taking the plugs out will allow the engine to (should) turn over very easily, no compression.  It won't really tell if the engine is ok though.  Too many variables there.  It will tell you that it is not locked up is all.
Lets go back to when it all started, tell us what it did, what happened...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stanley Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2019 at 11:27am
Solved the problem. It was the starter. Had it checked once and was told it was ok, but after exhausting other suggestions offered by forum members, I went back to the starter. Thanks to all for the help.
