190XT turbo |
Charlie175 ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6368 |
![]() ![]() ![]() ![]() ![]() Posted: 21 Aug 2018 at 6:56pm |
Looks like I am in need of a Turbo as the mounting flange is falling apart.
Need Exhaust Manifold and Elbow My turbo has a TRW tag on it, but I can't read the numbers that good. I would like a direct replacement so my oil lines all work. Suggestions for Farm use? A&I? Worthington? Others? Someone suggested a Garret GT35 |
Charlie
TRW Valve Division
Model 370 F 70
Part 4021703 |
Charlie
JimWenigOH ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: NC Ohio Points: 1164 |
I'm in the same boat as you are Charlie. I googled "is Garrett turbo made in USA" and what I read from a former employee made me check them off my list. They're not made in USA. I'm in no big hurry, so will be interested to see where this post goes.
If exhaust housing is bad, I'm sure I Have one. MACK
You can replace the housing? Where mine bolts to the manifold is getting holes that I have epoxied.
Along with that I am trying to trace where I am getting oil from, it seems to be coming out of the manifold? So the turbo is leaking? The Valve cover I can't see a leak there. ![]() ![]() ![]() ![]() ![]() |
Charlie
I found out that Turbo was shipped on Gleaner G Combines with the 2900 series motor. Not sure how it ended up on this tractor.
I would remove the Turbo to check for leaks but I think the whole thing will fall apart when I do. Might be my fall project.
Charlie
injpumpEd ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Walnut IL Points: 5075 |
I can provide new or reman turbos. No knock off junk either.
rog 190xt x 3=? ![]() Bronze Level ![]() ![]() Joined: 22 Jul 2012 Location: Grantsburg Wi. Points: 27 |
Hi I had the same leak on my 190xt I though it was the turbo leaking oil. It wasn't , it was a bad tip on a injector and was running fuel in and not spraying it and what I thought was oil was unburnt fuel .
Those turbos came on 190xt's , 3 of the 4 190xt's I have has them on them . The other has the 2 bolt return line on it. You could use either if you have a tractor salvage yard by you . You can pick up the other lines pretty cheap . Not much call for them any more .
AllisChalmers37 ![]() Orange Level ![]() ![]() Joined: 11 Jul 2010 Location: London,KY Points: 1846 |
![]() My turbo on my 190XT is in rough shape as well. It’s a Rotomaster tho. Never heard of them before Edited by AllisChalmers37 - 30 Aug 2018 at 9:17pm |
tbran ![]() Orange Level ![]() Joined: 14 Sep 2009 Location: Paris Tn Points: 3496 |
The oil from the manifold is likely oil coming past the valve stems at low idle. This usually clears up under boost and higher temps... the oil is burnt plus there is positive pressure holding the oil back..
