500 loader
 Rating: Topic Rating: 1 Votes, Average 4.00  Topic Search Topic Search  Topic Options Topic Options
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Topic: 500 loader
    Posted: 19 Aug 2018 at 1:33pm
Some time back there was a discussion about cylinder seal/packing kits for the 500 loaders.  Can someone update me.  Was that Baum that had kits?  Thanks....Dale
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2018 at 3:00pm
Dale, I do not know about that discussion but Baum can pretty much help on any parts for rams. I've even sent ends to them when we could not figure out what I needed. Phone # is 800-642-9333. All I can say is it's not often it seems like you need help. LOL Den
Edited by den/southern illinoi - 19 Aug 2018 at 3:01pm
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor.
185turbo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 185turbo Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2018 at 3:19pm
I bet baum has them . Pretty sure you can still get them from agco as well.
185 turbocharged w/ 500 loader , WD
SteveMaskey(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2018 at 3:40pm
I have 2 500 loaders and when I need repairs I just take it apart and take orings and seal to local hydraulic shop and they match it up. Much cheaper than buying kits
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2018 at 4:20pm
As Steve said, I rebuilt 1 bucket cylinder and a main lift cyl last winter for $100 worth of parts from local shop.
Leon B MO
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2018 at 9:40pm
Dennis...Thanks...But that is because the right people let me hang with them...The scary part is I was involved in the conversation and had seen those Baum kits.  Leon/Steve...Does the 500 on a 180 have bigger lift cylinders {2.5} like what is used on the 7000.  Parts for the 517 and 519 interchange with the 400 Series....Thanks...Dale
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2018 at 7:02am
Can't say for sure if the 500 cyl will interchange with other series, I do know there are different length cyl for them. We have 2 500 loaders and one is about 8" longer and the posts are taller. Both mounted on XT's
Leon B Mo
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2018 at 12:32pm
Both of my loaders are the same bucket and lift 1.5” shaft maybe 2” bore? I don’t have one apart to get a accurate measurement
chalmera View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chalmera Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2018 at 8:38pm
What about rebuolding the   spools?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2018 at 9:04pm
Chalmera, the loaders I have run off the tractor hydraulics they don’t have their own valve
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2018 at 10:47pm
https://www.allischalmers.com/forum/tilt-cylinder-500-series-loader_topic145098_post1202146.html?KW=#1202146
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2018 at 11:48pm
   Nathan...I thought is may have been you.  Thanks for jumping in and bailing me out...I know I had it saved..Now I will have it saved in two places...Dale
This page was generated in 0.143 seconds.
