wd45 hydraulic pump removal |
blumrs3 ![]() Bronze Level ![]() Joined: 04 Aug 2018 Location: Marion, IL Points: 2 |
![]() ![]() ![]() ![]() ![]() Posted: 04 Aug 2018 at 7:20pm |
Can someone tell me how to remove the hydraulic pump from a WD45 Allis Chalmers tractor?
TedBuiskerN.IL. ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Davis, IL. Points: 1959 |
You can get it off without removing the frame rail, but you have to depress and hold the cam followers, two short 1/4 in bolts flattened and inserted at the pivot points will work. You may have to cut the heads off the bolts.
Sugarmaker ![]() Orange Level ![]() ![]() Joined: 12 Jul 2013 Location: Albion PA Points: 8449 |
Frame rail off is the best but its not the eaisiest!:)
I have never taken one out with the frame rail in place. I have heard about nails holding things too. Regards, Chris
Four fingers on the four pumping plungers and it will come right out. No problem. MACK
Auntwayne ![]() Orange Level ![]() Joined: 23 Apr 2011 Location: Edwardsville Il Points: 1589 |
We have replaced 3. Never removed rail or cut bolts.
Dad always said," If you have one boy, you have a man. If you have two boys, you have two boys". "ALLIS EXPRESS"
Brampton 02 gt ![]() Orange Level ![]() Joined: 07 Apr 2011 Location: Erin,ON, Canada Points: 321 |
Harder to put back on with out ripping new paper thin gasket and or getting dirt or grease onto back side of pump. Just takes some patience. It needs to find the right angle to slide in.
Edited by Brampton 02 gt - 05 Aug 2018 at 8:27am |
albrown915 ![]() Bronze Level ![]() ![]() Joined: 27 Oct 2017 Location: Indiana Points: 65 |
4 of8 or 10 penny nails flattened a little and bent just a hair inserted between each roller arm and housing. Then pump will slip in .
irlbeck A-C'S ![]() Orange Level ![]() ![]() Joined: 28 Sep 2009 Location: Crestview FL. Points: 689 |
As others have said, It will come out and go back in without taking off the rail. Just need to wiggle it in and out. The pickup tube bends downward from the bottom so you will need to pick it up and tilt it so it will clear. The hold valve unbolts from the top. I found it easier for me to disconnect one line at the adapter on the back of the hold valve and the others can be disconnected at a swivel connection on the other end of the hose.
Also seems like i may have double nutted a couple mounting studs to remove them and that gave me a little more clearance. It's been a few years though. Hard for me to remember things from yesterday. LoL... After thinking a bit. It may have just been the bottom stud i took out. Seemed to make it a little easier going back in. ![]() ![]() ![]() Edited by irlbeck A-C'S - 05 Aug 2018 at 4:20pm |
B,C,CA,(2)WC's,(4)WD's,(2) WD45'S, 45Diesel, (2)D12'S Series 2, D12 Hiclear,(2)D12 Series 3, HD3, D17NF (3)D17 Series 4 Diesels, M-100 Grader,8550,A few Lawn tractors lots of other AC stuff
B26240 ![]() Orange Level ![]() Joined: 21 Nov 2009 Location: mn Points: 3865 |
When you get it out make sure you clean oil sump, mine was black slime on the bottom. Makes me wonder how long the engineer worked on this to make the least possible amount of room to r&r pump.
Alvin M ![]() Orange Level ![]() Joined: 24 Jun 2018 Location: PA Points: 800 |
take pto shifter off. remove pump out the bottom .put in from the top. push plungers in with fingers lay pump in rail put gasket on studs push in on pump put on nuts .that is how I do them
chalmera ![]() Bronze Level ![]() Joined: 22 Jul 2018 Location: In your head Points: 20 |
You'll probably mess it up the first time. I always do. Take off the rail, fewer than a dozen bolts. Chase all threads, clean, make room, give yourself a good chance to get it right. If it leaks, it will be easy to fix next time.
Put gasket I last. With pump started in hole, slide gasket around pickup tube and onto studs then pump onto studs. Have hundreds out and in over the last 50+ years and never tore a gasket. MACK
OwlCreekFarm ![]() Bronze Level ![]() ![]() Joined: 05 Feb 2022 Location: Clay City, IN Points: 9 |
I know this is an old thread, but perhaps someone is still around. Does anyone know where to get a pump rebuild kit? Is it difficult to rebuild?
Allis dave ![]() Orange Level ![]() Joined: 10 May 2012 Location: Northern IN Points: 3031 |
AGCO still sells rebuilt parts and kits for these. I rebuilt mine about 12 years ago. It's not hard, just be careful. Get a WD45 service manual off email, it explains the rebuild well.
dr p ![]() Orange Level ![]() Joined: 24 Feb 2019 Location: new york Points: 1389 |
I think Chris pointed a thread of a rebuild a while back
Thanks! I called AGCO and they no longer carry any replacement parts for the hydraulic pump. Any ideas of aftermarket resources?
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8573 |
I'd be suspecious of that answer. Sounds like lazy parts help. I'm sure you can't buy plungers or sleeves but can't believe they don't still have seat,balls and springs. Everything else is gaskets and orings.
Albert ![]() Silver Level ![]() ![]() Joined: 11 Sep 2009 Location: NW MO Points: 410 |
Ziegler AG Maryville MO keeps the Gaskets seals o-rings and most of the springs in stock also keep the balls. 660 582 5150
Albert
Thad in AR. ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Arkansas Points: 9640 |
Hello Albert. It’s been a while. I believe you sold me my rebuild kit for one of my 45’s back in the Dean ag days. Glad to see you on here. I just bought a new project. Will be calling you. |
I would get a parts books off ebay or lookup the part on AGCO's site. I bet they'd have them if you actually gave them part numbers.
You may ask Brenda at Sandy Lake Implement. That is where I got my kit. But it was a couple years ago?? There are a lot of parts in there! Just sayin.....
Regards, Chris
Edited by Sugarmaker - 13 Feb 2022 at 5:51pm |
