B/C oil lines
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Topic: B/C oil lines
    Posted: 27 Mar 2018 at 2:18pm
Im adding a distributor to my C and need to get a T for the oil lines to get oil to the distributor gears.  The parts book shows a special fitting  but doesn't list the size.  Is the line 1/8?  And on top of the governor where the T is placed is what is the fitting size?  I was planning to hit the hardware store after work but forgot to bring the lines and existing fittings with me.  the lines are original steel with ferrules.  can I get something to work here or is it going to take several pieces to get where I need?
thanks
Edited by CAL(KS) - 27 Mar 2018 at 2:23pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2018 at 6:01pm
some of those small lines are the same size as the line in an AFTER MARKET oil gauge set.. They give you a small copper or plastic tube with a couple brass fittings and ferrel seals on the ends..... If there stock of " tubing" and "fittings" are all too big.... go look at the aftermarket oil gauge kit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2018 at 9:23pm
yep, you are right.  1/8 inch or same as oil pressure line.  i ended up having the distributor setup in my vehicle so i had something to go by but no luck at hardware store or local carquest. That is a goofy fitting with a female on the bottom and the other 2 male ends in 1/8.
