Electronic Ignition Upgrade ? |
FREEDGUY
Topic: Electronic Ignition Upgrade ?Posted: 17 Mar 2018 at 9:05pm |
To those that have done the upgrade,is it necessary to change spark plugs? This would be on a 180. Thanks. By "change", I mean get a different AUTO LITE # or perhaps brand?
MACK
Posted: 17 Mar 2018 at 10:14pm |
No. MACK
DougS
Posted: 18 Mar 2018 at 6:07am |
Perhaps keep the original kind of plugs, but I'd replace the wires with resistor wires, if it doesn't already have them.
Posted: 18 Mar 2018 at 6:31am |
If I didn't have a radio on it, I'd never ever use resister wires instead of wire wires.
DougS
Posted: 18 Mar 2018 at 7:32am |
Pertronix requires it with their new modules. RFI causes problems with more than just radios. I'm beginning to think the few reports I've seen from users here of electronic modules crapping out is due to RFI.
dakotawc
Joined: 17 Feb 2013 Location: Clayton SoDak Points: 58 |
Posted: 18 Mar 2018 at 7:40am |
If you also upgraded the coil, try experimenting with a wider plug gap.
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7569 |
Posted: 18 Mar 2018 at 8:36am |
It is not necessary to change the plugs when switching to electronic ignition, but I would check them out while you are working on the ignition system. Recently I have been buying NGK spark plugs and have had good luck with them.
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12043 |
Posted: 18 Mar 2018 at 9:08am |
Doug is right on. We got a bulletin last summer on RFI playing havoc with E.I.'s from Pertronix. Ever since we got that bulletin, if a customer purchases an E.I. kit from us, I always ask them to check to see if the Tractor has solid core wires on it. Most of the time, they do, so I tell the customer we offer a resistor wire set or they can purchase a resistor set locally if they want, just so they don't lose that E.I. on a stray spike from the solid core wires being used. This does not effect performance at all on Battery Ignition systems. Pertronix was getting a lot of failed E.I.'s back from the Tractor folks, and they think they finally figured it out. Since I started this program with us, I haven't had one call about a E.I. failing yet. So far, so good....
BTW, forgot to add, you don't have to change the plugs or coil. There is an optional Pertronix 40K coil that available, but not neccessary as long as you have the correct Coil for your particular application...Steve@B&B Edited by Steve in NJ - 18 Mar 2018 at 9:11am |
ac45dave
Posted: 18 Mar 2018 at 10:27am |
Brian Jasper co. Ia
Joined: 11 Sep 2009 Location: Prairie City Ia Points: 10508 |
Posted: 19 Mar 2018 at 6:43pm |
My CA and Oliver 60 have both been running .045 plug gaps. They each have never started so well and ran so smooth. Plug fouling is a thing of the past.
Charlie175
Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
Posted: 20 Mar 2018 at 6:32am |
Hmm, my 45 and 17 has Pertronix, can't remember switching out the plugs, wires or the coil at that time several years ago.
Charlie
BrianC
Joined: 16 Jun 2011 Location: New York Points: 1619 |
Posted: 20 Mar 2018 at 6:53am |
From the install sheets:
"Leaving the ignition “ON” with the engine “OFF” for an extended period could result in permanent damage to the Ignitor".
Lonn
Posted: 20 Mar 2018 at 7:23am |
Wink I am a Russian Bot |
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
Posted: 20 Mar 2018 at 7:47am |
3 years and going on my UC puller with petronix and solid wires. 3 ohm oil filled 40k coil, no external resistors or bologna to be exposed. toggle switch ignition and a light on the dash so it doesn't get left on
Edited by CAL(KS) - 20 Mar 2018 at 7:49am |
DougS
Posted: 20 Mar 2018 at 3:56pm |
In my countless years as a communications tech I've learned that you cannot predict how RF will act and how one component may tolerate it well, yet another unit will not. Someone else with an identical setup to yours may not have the same luck. I'd prefix your statement with a YMMV. |
CAL(KS)
Posted: 20 Mar 2018 at 4:06pm |
whats ymmv? lol
BrianC
Posted: 20 Mar 2018 at 6:14pm |
On PerTronix website in the Frequently Asked Question section:
Its very important to verify that your spark plug wires are compatible
with the ignition system, or any on-board electronics in general. Solid
core wires have a copper or stainless steel conductor and generate
excessive Electromagnetic Interference (EMI). This EMI can create
confusion with electronics and ultimately damage them. With all
PerTronix ignitions we recommend that a suppression style spark plug
wire (also called carbon core) be used. The suppression wires do an
excellent job of controlling the EMI with no degradation to the ignition
performance.
Help Topics:
Ignition General Help, Ignitor Application Inquiry"
I would add that carbon core wires have a limited lifetime. |
cwhit
Joined: 12 Sep 2009 Location: Sigel IL Points: 1006 |
Posted: 20 Mar 2018 at 6:45pm |
We have 4 tractors with pertronics. CA, WD, WD45 And a D17. All trouble free EXECPT the WD. Guess it’s time to check the wires on that one.
JayIN
Posted: 20 Mar 2018 at 7:55pm |
Dammit! Now I gotta go outside and look.....
DougS
Posted: 20 Mar 2018 at 8:05pm |
Your mileage may vary. :) |
CAL(KS)
Posted: 20 Mar 2018 at 9:19pm |
Ah,of course . Yes, not saying i was doing it the right way but only that i had not had trouble. And if pertronix is recommending surpressor wires now then we should be following suite to insure good service life.
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24878 |
Posted: 21 Mar 2018 at 5:57am |
re: this quote from the manufacturer..
"This EMI can create confusion with electronics and ultimately damage them." I'd like to know why they haven't added EMI supression to their units. This isn't 'rocket science' or expensive, less than $2 per unit, and would allow the unit to survive the low energy EMI the coil/plugs produce. 30 year ago my energy control system would servive near field lightning strikes,unlike the PCs sitting next to them. Selling a product with a known defect just ain't right in my books. |
DougS
Posted: 21 Mar 2018 at 6:30am |
Well yes, they could build it to mil specs too, I suppose. Have you priced mil spec items lately? As another (I forget who) pointed out a couple of weeks ago, it's best to use suppression on battery ignition systems anyway. He stated the reasons why. I'd look it up, but it's too early in the morning for my old mind.
Steve in NJ
Posted: 21 Mar 2018 at 2:43pm |
I've been reading here, and some of our customer's have been mentioning to me over the phone and in e-mails about the success they've been having with widening the gaps of the sparklers. I assume they are using the hotter 40K Coil to light that candle with the larger gap...
