Best AC loader tractor?
spencefarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote spencefarm Quote  Post ReplyReply Direct Link To This Post Topic: Best AC loader tractor?
    Posted: 16 Sep 2017 at 10:40pm
Hey guys, Just curious on what your thoughts are on what's the best tractor for a loader tractor?
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2017 at 10:41pm
Any specific vintage or hp range?
DakotaSteve View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2017 at 10:44pm
I think in older stuff a WD45 w power steering and an Allis 445 loader would be pretty slick.
Post Options Post Options   Thanks (0) Thanks(0)   Quote spencefarm Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2017 at 10:48pm
I'm thinking D series or newer. Even the 100 series maybe?
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2017 at 10:51pm
I have a D-15 series II with rear wheel weights.  Works great and highly recommend!
Post Options Post Options   Thanks (0) Thanks(0)   Quote spencefarm Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2017 at 11:15pm
Are the hydraulics strong enough to run a decent size loader?
Post Options Post Options   Thanks (0) Thanks(0)   Quote spencefarm Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2017 at 11:20pm
Also, what loader do you have on it?
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2017 at 7:17am
My I600 is a pretty decent loader tractor for its size.
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2017 at 9:10pm
D19 with a dual loader and a front mount pump or maybe 170 - 185.  The 190 and 200 are ok if you want a loader tractor where you sit up a little higher.
Michael Crowe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2017 at 9:59pm
Steve, the tractor you describe is exactly what I have; a 1953 WD45 with factory power steering that I added, a 445 loader and a machined brace for the front axel so I don't bend it. I'll take a picture and post tomorrow. I had a 519 loader on my D19D but wouldn't use it in the winter do to it being hard on the motor so I sold the loader and had Don Bradly rebuild the engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2017 at 10:02pm
Michael, Yes. I think if I can track a good 445 down it will suit me well!
Farmerhg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farmerhg Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2017 at 10:48pm
I'd have to say a D17 series 4 makes a really good loader tractor.I've had an AC Model 170 on up to a Westendorf WL-42 on mine.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2017 at 5:58am
If you are going to be using it much as just a loader tractor, I would recommend one with a Shuttle Clutch.
I have a D-15 II with a 415 loader, and you are continually shifting forward to reverse.
Gary
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2017 at 6:42am
I like my 160 with its loader.
steve fischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve fischer Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2017 at 7:14am
I have a 170 with 500 allis loader love it , hydraulic steering and tractor controls for loader
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2017 at 7:34am
X2. Mine has the AC power crater 226 engine.
dave63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2017 at 5:13pm
6060 or 6080 4WD hands down the best loader tractor. unless you are stuck in the 50's or 60's
The universal answer to all questions is yes, how much do you want to spend?
ksbowman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ksbowman Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2017 at 5:44pm
I prefer the 170D with a 500 loader too. I have a 180 and 190 but, like to use the 170 for loader work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2017 at 8:03pm
SpenceFarm:  The hydraulics on the D-15 Series II work great.  It was one of the last ones made.  I have a snow bucket on it.  Loader was made by Paulson.  Hope that helps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2017 at 9:15pm
Depends on the job, to plow snow something with 4 wheel drive and a good cab.
LaJaMe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LaJaMe Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2017 at 10:59pm
D17 w/ L200 industrial loader with front pump.  Very versitle
SteveMaskey(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2017 at 5:04am
I have 5 tractors with loaders, WD45—New Idea Horn loader, I400 loader backhoe, 2 – 180 with 500 loaders and 8030 FWA with Westerndorf loader. The big tractor will lift the most, but for feeding and general loader work I like the 180. They are easer to get on and off and have better visibility.
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2017 at 6:54am
I wish my WD had power steering and a Shuttle....  that's all it needs.
I have however learned to only steer while rolling, and just stop and shift.
alleyyooper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alleyyooper Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2017 at 7:06am
I was trying to buy a 175 D with a loader  I thought would do all I wanted to do. But the dealer was stuck on his price despite me showing as nice tractors a little farther from home for a good bit less.
So for a while longer I am stuck with my D17 with the Kelly light weight loader with manual trip bucket.
Is't the best rig but better than a mexicon drag line for moving dirt.
Big smile   Al
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2017 at 7:35am
My dad & uncle's dealership had a One-Ninety gas with an AC loader.  I don't remember the model number; maybe a 500?  We had forks on the front for moving pallets and also a boom that swung down with the forks in a narrowed position.  Used it a lot to move field cultivator frames, disc gangs, etc. to put the implements together.
I believe the tractor was a trade-in and then the new loader went on it.  Been too many years to remember for sure.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2017 at 11:13am
just one question , are you going to load or move big bales all the time
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2017 at 11:26am
We have a 1962 series II D-17 gas with a 500 loader.  The pump is mounted to the front of the tractor.
This was put on at the dealership in 1970.  They installed shims because the D-17 frame is narrower than some of the other tractors the loader will fit.  It is a great loader.
dt1050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2017 at 5:59pm
I got a d14 with a 445 loader and psteering. works great.  loaded the rear tires for a counter weight.
Dkienzle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dkienzle Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2017 at 8:15pm
6080 fwa is a heck of a loader tractor. Problem with them is I run out of traction long before I run out of power. They are really sweet it they have a foot throttle like mine does
Claus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2017 at 12:10pm
This page was generated in 0.071 seconds.
