Loader question.
Josh Day View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Topic: Loader question.
    Posted: 24 Jul 2017 at 7:18pm
Hi guys, I found this about an hour away from me the tractor has a cracked block but in the add it says 1500 for tractor and loader. My main want is a Loader for my D-17 series 4. My question is; what model loader is this if someone can tell, and would it fit on my D-17. Thanks!
AC's 75' 7040, 64' D-17S4, 55'WD-45, 54' WD-45, 53' WD-45, 53' WD, 52' CA, 36' WC. IH 656. Deere's 38' A, and 47' A
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2017 at 8:17pm
I think it would bolt right up to your Series IV. You best get the cash out and get that on your trailer. The loader is worth the asking price and the backhoe is probably worth more than the asking price. You can't go wrong on that deal, even if it didn't fit your tractor.
skateboarder68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skateboarder68 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2017 at 8:28pm
Its a model 500 loader, have one on a 185. No idea if it fits a D17
Orange & Silver still earnin their keep on the farm: R62, Series IV D17 nf, 185, 6080, 6080 fwa, 220, 1968 D21, 7045, DT240.
Chris View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2017 at 9:14pm
I have a 519 loader on my series 4
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2017 at 9:28pm
500 series. Can be made to fit your D-17 IV. Needs different brackets to rear axle ( easily fabricated) and spacer blocks between the side frames and loader frame.
ksbowman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ksbowman Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2017 at 9:51pm
I have the Model 500 on my 170D can't be to much different. It was on a 180D when I bought it.
Edited by ksbowman - 24 Jul 2017 at 9:52pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2017 at 10:00pm
170 and 180 use the SAME axle brackets.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2017 at 4:08am
Josh
You should already have that in your yard.
A 190XT with good tires, front weight, AND a hydraulic loader for $1500 !!
AND it runs !!
Gary
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2017 at 6:44am
If the crack is external, use like it is after fixing the crack..  ;)
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2017 at 6:57am
If it's a diesel, and the problem is antifreeze in the oil, there's a chance it's an O ring on a sleeve, not a cracked block.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2017 at 7:31pm
So Josh did you buy the 190XT and loader ?
Gary
