Plowing with the WD45
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Topic: Plowing with the WD45
    Posted: 24 May 2017 at 4:28pm
Back in mid-April I was posting about adjusting my 2-bottom plow to fit the WD45. Finally got a chance to put the plow in the ground today. I worked the plow in a section that had already been plowed to polish up the bottoms. Though plowed, the ground is typical New England soil: BONY! So I kept the speed down. Here's a video - in 2nd gear with throttle open not much! I need to adjust the plow to cut deeper, but that will require me to free up the beaming crank! Also cutting deeper on the front bottom than the back, so I need to tweak how I've got the winging screw set. I'll get to these soon - supposed to rain tomorrow and Friday.
So, DennisA(IL) I am FINALLY able to tell you that it's working.....though not yet up to expectations. LOL Thanks to everyone who offered help back in April.
Comments/suggestions happily accepted!
BTW, I think the engine sounds better after a little work and a jug of Seafoam in the tank!
[TUBE]_pPAW_4M_Es[/TUBE]
I've added photos of both bottoms....front first, then rear.
Edited by Dave(inMA) - 24 May 2017 at 7:40pm
WC, CA, D14, WD45
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 6:22pm
Sounds good, plow looks set up correctly, though I am not an expert!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 7:37pm
Stan, thanks for commenting.
The plow isn't sucking deep enough. Not sure what the cause is. I've added photos of both bottoms to the original post to see if the plow people out there think the tip shapes are okay.
Dave
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2017 at 7:49am
After freeing up the beaming screw, I raised the back of the plow relative to the front - now sucks deeper. I think the idea is that the plow 'wants' to run level front to back, so raising the rear bottom makes it drop deeper into the soil to get to level. Maybe!
Kinda fun listening to that 45 engine when the pulling got harder. Big smile
WC, CA, D14, WD45
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2017 at 8:05am
Get yourself a snap coupler ripper it'll hook those rocks and get them up out the ground so
you can haul them off.
dt1050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2017 at 8:09am
aint nothing like the sound of an old Allis working.  music to my ears..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2017 at 12:10pm
Haven't seen a SC ripper around here lately! Or at all, to be honest. In addition to rocks, we also have ledges - might get exciting if I hooked onto one with a ripper. LOL
Every time I plow here I end up with a lot of rocks to pick up.....and there's always more the next time!
WC, CA, D14, WD45
