gas tank top repair
ac2020 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac2020 Quote  Post ReplyReply Direct Link To This Post Topic: gas tank top repair
    Posted: 11 Apr 2017 at 8:10pm
seen on ebay replacement gas tank tops that you weld on has anyone tried these? was listed for wd and wc tractors
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2017 at 10:20pm
you can cut one off a junk tank' an weld it on the good one' someone has a bad tank with a good top on it' bottom rusted out is what you need? parts tank;;
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2017 at 6:27am
why would they sell a half-tank?
And do they make tank bottoms?
Edited by corbinstein - 12 Apr 2017 at 6:28am
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac2020 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2017 at 8:06am
it is just the bung on the top of the tank
not the top half of the tank
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2017 at 11:24am
Are you just looking for a new neck for the tank??
$2.99 + S/H (VERY reasonable!!)
http://www.fillernecksupply.com/304-stainless-filler-neck-2-28-58mm-x-0-64-16mm-na1375ss304/
Also, they have a new cap also  $7.99 + S/H
http://www.fillernecksupply.com/vented-bayonet-cap-with-finger-grips-fits-2-28-od-necks/
Not an Allis cap, but it'll do.  Looks nice on my C
Edited by Ted J - 13 Apr 2017 at 9:41am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2017 at 11:34am
ac2020 did you see this?  Did it help?
It's the cheapest that I could find on the net.  A lot of place want a minimum order, they don't here.
45 turboa- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 45 turboa- Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2017 at 5:04pm
I put a new one on my WD45 un soldered the old one the new one fit in the hole perfectly but I can't remember were I got it from.
turbocharged
This page was generated in 0.045 seconds.
