BRAKE LOCKING 200 ALLIS
ac-mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac-mike Quote  Post ReplyReply Direct Link To This Post Topic: BRAKE LOCKING 200 ALLIS
    Posted: 17 Jan 2017 at 8:16am
I HAVE A CUSTOMERS 200 ALLIS IN SHOP. CUSTOMER SAYS THE RIGHT BRAKE LOCKS UP AND HAVE TO ROCK IT TO GET IT TO RELEASE. THIS IS A LATER STYLE 200 BRAKE SET UP. USUALLY THIS IS CAUSED BY, OIL LEAK,OR PADS WORN OUT, OR DISTANCE BETWEEN INNER AND OUTER BRAKE DRUM PARTS BECOMES TO WIDE. THE EARLIER STYLE BRAKE SETUP IS SIMILAR TO 100 SERIES TRACTORS. SHOP MANUAL GIVES ALLOWABLE DIMISION BETWEEEN BRAKE DRUMS.
MY SHOP MANUAL GIVES NO DIMISION BETWEEN BRAKE DRUM PLATES ON TRACTORS WITH THE NEWER STYLE BRAKES. SHOULD THIS BE A CONCERN? WHAT ELSE MIGHT CAUSE BREAK TO LOCK UP? BRAKE DISCS SHOW VERY LITTLE WEAR AND NO OIL LEAK.
old farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote old farmer Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2017 at 10:37am
Could be a problem in the rear end. Have seen this before on some tractors.
Tony Elo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony Elo Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2017 at 12:59pm
Is it the style of brakes like the 7000 have? Discs with ball bearings on a taper to push them out? if so,make sure where the ball bearings slide is smooth,also check them for any flat spots
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2017 at 1:14pm
My belief is that the splines get worn in the discs (sharp) and cause this problem. Look at that area closely.
Rhoadesy_65 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rhoadesy_65 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2019 at 7:12am
Do you remember what ended being the fix for this? Mine does have oil in one side, but the other is dry
Farmin' with 1981 7010 PD, 1983 6080, 1983 8010, Gleaner R42 in Darke County OH
