What 6 bolt hubs?
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Topic: What 6 bolt hubs?
    Posted: 02 Jan 2017 at 11:49am
Will work on a WD?
I have a nice set of 7.5L 15 tri ribs on 6 bolt rims I want to put on the front of my wide front 45. Need a set of hubs that will work.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2017 at 12:38pm
I believe 6 bolt hubs from an early WC will fit on those spindles.
littlemarv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2017 at 2:04pm
I think so too. I took wheel bearings out of a WD and put them in the 6 bolt hubs on my WC.
The mechanic always wins.
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2017 at 6:51pm
thank' the oliver 77 6 bolt hub will also work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2017 at 7:23pm
Thanks for the ideas, any others?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2017 at 7:32pm
have them tires mounted on your wd rims' would be less work' much cheeper.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2017 at 10:40pm
I'm thinkin them rims are a bit wider than skinny WD's. I put some GM(Buick?)rims(15x6 I think) on my 45.Had to skin a little outa the center but not much.Think they are the same size as his...7.5L's
Edited by SteveM C/IL - 02 Jan 2017 at 10:46pm
Bill Deppe/AC Salvag View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Deppe/AC Salvag Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2017 at 11:03pm
Have a set of WC 6 bolt hubs on my reverse WD, fitted on without making any changes
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2017 at 6:21am
I know GMC truck rims fit the CA rears. Had to flip them 'inside out' but it sure made moving it easier!
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2017 at 12:21pm
They are 15" tires. I bought the rims from a coworker pretty reasonable, believe they came off a 4020. I painted them white because they may wind up on the 185 but would rather put them on the 45 if I can find the right hubs and put new 11L15s on the 185.
michaelwis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2017 at 12:40pm
We put 6 bolt hubs on our D15 many moons ago.
Got them from Tractor Supply in Madison
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60   GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2017 at 7:00pm
If you can find trade numbers for the bearings and exact dimensions on the spindles, its possible there might be a stock hub from Baum Hydraulics http://www.baumhydraulics.com or Shoup http://www.shoupparts.com
If you dig into the tapered roller bearings of the Baum catalog you will find that there are several cones and cups that have the same roller dimensions but sometimes a wide range of spindle and cup dimensions, so the critical dimension on the hub and spindles are more often the length between the places the bearings ride. Baum also sells seals, another variable.
I know one of the stock hubs that both of those places carry fit my AC plow when I broke the hub.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2017 at 10:08am
Thanks for the ideas guys, much appreciated.
This page was generated in 0.166 seconds.
