what model is this?
Kev View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kev Quote  Post ReplyReply Direct Link To This Post Topic: what model is this?
    Posted: 18 Dec 2016 at 2:08pm
Hello, my father has this Allis Chalmers crawler and we are trying to find out the model but the diamond is empty, no model mark. Anyone have any idea? He reckons it's very old.
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2016 at 2:11pm
 looks like a "M"
Thanks & God Bless
Dennis
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2016 at 3:21pm
Yep, it's an M.
Farrell(Utah) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farrell(Utah) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2016 at 3:47pm
Definately an M crawler as previous posts have indicated.  They made a narrow track model and a wide track model.  I had a wide track model that had a WM serial number.  Not sure if the narrow track models had a designation for the track width.  They are cool old tractors.
A(1937), 2 G, 2 WD45 diesels, 6 WD45 gas, UC, 2 WD, D17 gas, WF, Farmall 400, D12, Kubota B3030
Kev View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kev Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2016 at 3:54pm
Any idea why there is no M in the diamond?
Also any idea how old it might be?
in case I forget later thanks for the help with this
Dek Thorne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dek Thorne Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2016 at 4:23pm
Nice looking crawler. looks like it needs to get out and play. Old crawlers dont like to sit around.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farrell(Utah) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2016 at 4:24pm
No idea why the M is missing:  probably been removed during the years.  The serial number is by the gear shift handle.  You can check this against a serial number registry.  Your tractor has the later manifold so I am guessing it is a 1937 or newer but this is just a wild guess as modifications were often made to these tractors.
Dave Everett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Everett Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2016 at 11:35am
M with a U radiator fitted as there shud be a hole in each corner of the diamond for fitting nails (rivets) to hold mhe M badge, same castings were used on the M WM UC and U
Why?
This page was generated in 0.081 seconds.
