Time a D17 |
cnafarms
Joined: 01 Jul 2011 Location: Mt. Airy, MD Points: 140 |
Topic: Time a D17Posted: 22 Oct 2016 at 7:02pm |
Ok so I need to know the correct way to time a d17. In the inspection port on the side of the tractor when number 1 plug fires should the F-25 that's on the flywheel be visible in that inspection port. I'm guessing yes. The only problem is with mine that once a load is put on the engine it starts to miss loses power. Do also when you time it is it at idle or full throttle. I've read both looking this up on different websites some say at idle and some say full throttle. Any input is appreciated.
Thanks Chris |
Posted: 22 Oct 2016 at 7:30pm |
WIDE OPEN....FULL THROTTLE....F-25.
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5083 |
Posted: 23 Oct 2016 at 6:28am |
Is the mechanical advance working? They tend to get neglected and set up on these old tractors.
LeonR2013
Posted: 23 Oct 2016 at 6:57am |
Wouldn't checking your timing at idle and wide open tell you if the advance was working?
Posted: 23 Oct 2016 at 7:47am |
Correct. At high idle it needs to be F-25. At a very low idle (400 RPM) it should be close to TDC.
