D-17 hydraulic leak?
farmboy59 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboy59 Quote  Post ReplyReply Direct Link To This Post Topic: D-17 hydraulic leak?
    Posted: 14 Oct 2016 at 8:49am
I have a 59 series one D-17. It has a hydraulic fluid leak and I can't tell where it's coming from. Where it's coming out of is the inspection cover in the torque tube behind the flywheel. Just trying to figure out what I have to do to fix it. So far I just keep oil around to keep the level up so I can use it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2016 at 9:08am
If it's the round cover on the right side, there's a gasket on that plate. If it's coming from behind the side panels, you'll have to remove the side panel to see where it's coming from.
bigredisb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigredisb Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2016 at 10:27am
The other thing I use for hard to find leaks is to put uv dye in the oil that you think is leaking and run it, then check with a UV light. Gives you a perfect look at where its coming from. You can get it at any parts place around here.
1961 Allis-Chalmers D15
1949 Farmall Super A
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2016 at 12:36pm
Seal on the input shaft going into the transmission?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2016 at 9:41pm
Could be the rear main seal of the engine or the front seal in the torque tube.  I usually replace both whenever I am in there.  You will need to split the tractor behind the engine.  It is also a good opportunity to check out your clutch assembly.
