D14 Question |
Tim NH
Joined: 16 Oct 2012 Location: Lancaster NH Points: 1137 |
Topic: D14 QuestionPosted: 11 Oct 2016 at 4:47pm |
I would like to look at the screen on the oil pump. It looks like the oil pan would slide ahead, thru the wide front end, then down and out. Or, is the front end in the way, and has to be taken off. Thanks Tim
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7566 |
Posted: 11 Oct 2016 at 8:47pm |
Never tried taking the pan off while the axle is on. I always removed the axle first, then there are no obstructions.
Dan73
Joined: 04 Jun 2015 Location: United States Points: 6054 |
Posted: 11 Oct 2016 at 9:08pm |
Tim on my d17 we did remove the oil pan to see what was wrong with the motor before removing the front end. It was a bad idea we fought with it for a very long time a couple of bolts where really hard to get out and it ended up hung up when we dropped it down. I don't know about the d14 but if it looks tricky I would rather remove the front axel it comes out pretty easy actually.
Edited by Dan73 - 11 Oct 2016 at 9:09pm |
