D17 series 4 questions
Josh Day View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Topic: D17 series 4 questions
    Posted: 20 Aug 2016 at 9:06am
Hi guys, rebuilding thewide front end how do I get the tie rod arms off the top of the spendals one guy told me you have to cut them rebuild it then clamp them togegeather on the spendals then weld it back togeather. and also going to go through the hydro pump and power steering pump and assist cylinder. Any good pointers before I do this. Thanks
AC's 75' 7040, 64' D-17S4, 55'WD-45, 54' WD-45, 53' WD-45, 53' WD, 52' CA, 36' WC. IH 656. Deere's 38' A, and 47' A
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2016 at 8:48am
Best way to get steering arms off is to remove snap ring, remove wheel, remove axel assay, turn upside down then slide back in. Take a sledge hammer and beat arm off.
Easier  for a younger man than a old &%$# like me.     MACK
